Can't change notification color on red series dimmer
I have a few automation setups through home assistant that change the red series on/off to green or red based on whether or not my door is unlocked. I wanted to create another automation so that when my alarm is “armed_home” it will change the color. But for some reason, my led notification is just staying the solid blue (on @ full brightness). I posted a few screenshots below. am I missing something? Do I need to update my switches or something?
Turns out I needed to set the parameter: '8' to parametrer: '16' since it is a dimmer switch
