I have a fan switch in a 4-gang box. I was trying to just turn it to an on/off (exhaust) switch. But no matter how many times I try to convert it when I click on the switch in Home Assistant it still shows high, low, and medium. Instead of just on and off.
I noticed in the manual that, “Smart Fan Mode is used if 2+ Smart Switches are on the same circuit.” The neutrals are daisy chained in the gang box. Is this what the note means. When I first read it I assumed it meant two or more switches connected to the fan, but now I’m not sure. Any insight?
Can you clarify what you mean when you say “neutrals are daisy-chained”?
Like grounds, all neutrals in a box need to be tied together. For each smart switch, use a pigtail from the main neutral bundle in the box.
If more that a few neutrals are in the box, it can get dicey keeping them all well-connected under one nut. Make sure you use an appropriately-sized nut and that the integrity of connections under it are good. Or just use Wago lever-nuts – they’re awesome.
I’m guessing the OP is referring to using the second hole on the switch to go from switch to switch. Perfectly acceptable with a neutral. It is the grounds that you should not daisy chain.
This doesn’t sound like a wiring problem, it sounds like a HA problem.
Indeed they do! Thankfully never had to use it for real.
Closest I ever got was a rogue old-FSU tracked-vehicle missile launcher that used to haunt around in Bosnia back in the late 90s / early 00s… It would light you up every now & then (that gets your attention fast!), but AFAIK that bubba never actually launched on anyone.
I believe the fan switch always shows up as a multi speed fan to Home Assistant regardless of the mode it’s in. No matter what speed you select, it’ll be going at full speed when in exhaust fan mode.
Agreed, the devices don’t change how they present to Home Assistant when their mode is changed. A 2-1 or dimmer also always appears as a dimmer even in on-off mode.
Thank you gentlemen. That answered my question. PJF is correct. My one light switch that is in on/off mode, still shows up as a dimmer in home assistant. Slightly annoying, but at least I know it’s not something I did wrong.
