Can't find the config folder for zwave with Innovelli
I’m using the VirtualBox installation of HA on a Windows host.
I’ve read the instructions to integrate Innoveli with HA however I can’t find the config folder: https://support.inovelli.com/portal/en/kb/articles/installation-setup-lzw60-4-1-multi-sensor-home-assistant
Also, I’m a little bit confused about how to access terminal in the proper way. Currently I’m using the built-in terminal from Visual Studio Code. Also, how do you transfer files to HA when you know the config folder? Through Samba?
Is HA linux based? If so, you can use the wget command through terminal to get the config file. However, I’m not familiar with HA, so I don’t know the environment.
Go to directory via cd, download with wget.
wget https://raw.githubusercontent.com/InovelliUSA/OpenZWave/master/config/inovelli/lzw60.xml
I had the same question. I’m also using a virtualized Home Assistant. This is the OS: GitHub - home-assistant/operating-system: 🔰 Home Assistant Operating System
It is Linux-based, but it’s not based on a common distro like Ubuntu.
Are you using the default zwave integration or something like ozw beta or zwave2mqtt? Are you running the supervised homeassistant (has add-ons) or homeassistant core?
