I have the blue series Fan Dimmer but the low speed seems to be very low for my fan and then the medium speed becoming slow and then high speed being fast. How can i change this because it is not very viable at the moment
How do i go into device settings?
Can’t help you with HA. It’s wherever you go to set the device’s parameters. Someone else here should be able to give you some guidance.
Is it one of these things here?
In the hubitat driver it talks about those three parameters having to be bound to the ep3 controller up in the fan, which I’m assuming is the extra module. I’ve tried adjusting them But I don’t think it changes the actual voltage. I can try to test it again and confirm, But I believe the voltage remain constant.
Yeah, taking another look at that I think that really only pertains to binding. The physical output of the switch is via onboard capacitors. From the original description it almost sounded as if low in medium were the same. So those parameters are not going to vary the fan speed of the wired load.
OP, if your fan has a pull chain, did you set it to high?
Yea it is on the highest fan mode
