Clearing time parameter for occupancy sensor on mmWave switch
Folks,
What is the parameter to modify to clear the occupancy detected boolean value. right now it seems to be a little too long to see if the presence has been cleared.
It seems to be Parameter 114 however the description seems to be more about how long to keep the load on in the sensor. I just need to be able to change the amount of time it clears that parameter once no presence in the room.
114 is the right parameter. That is the delay after presence is no longer detected before the occupancy sensor actually reports no occupancy. The documentation says the default in 10 seconds, but every one of mine has a default of 30 seconds.
Agree with pkscout – 114 should be it.
I’m not a mmW connoisseur who’s tried a wide variety of these sensors, but in my experience, the detection timeout on mmW devices is inevitably laggier than the set value – e.g. a 10" setting tends to be more like ~30" in reality. PIR sensors can be this way too, but mmWs seem to be even mushier.
I realize there are a gaziliion device-level variables here between environmental, firmware, hardware, etc, but point is that some experimentation will likely be needed to dial in that timeout for your particular placement.
Got it.. ewill play with that.
Curious anyone seen the issue where occasionally when the mmWave sensor clears, the next occupancy is not registered. and I’ve seen vice versa as well where sometimes it will get stuck in detected state and not clear. happening 2 days straight on a newly installed switch.
Glad you mentioned this. The default for me was also 30 but the inline description said 10.
