Edge driver: Inovelli White Series 2026-03-26
Firmware: 1.1.5
I have about 20 dimmers to install, all white series using SmartThings. I can see in the settings for a given switch the color choice, brightness etc. Those only became available when I switched to the edge driver.
When creating a routine I do not see any color options as described in the instruction page.
Am I missing something to enable color notifications?
The 2nd “device” which was added when I switched to the edge driver had a generic name and I didn’t recognize it as the RGB light on the switch. Posting in case others need to look for a new device as well.
I’m new to Invelli. This is what I see so far.
The color of the color notification is set by the 2nd child device, or by a routine.
The behavior of the notification (pulsing, chase, etc.) is a setting on the main dimmer device. Also, cannot be set by a routine.
So pick the one behavior for the switch for all possible notifications, and then set colors for each one in their routine.
Please let me know if I an not understanding correctly. Thanks!
