I am trying to setup a flow with my VZM32-SN via zigbee where when I push the config button it turns on something else. However, when I try to do this on homey it doesn’t work 95% of the time.
I tried switching to home assistant and it works flawlessly but ideally I would like to use homey if possible. I tried using the test homey app as well but same result. Thank you!
