Configuring LED Color and Double-Press Automations for Matter Smart Dimmer in Home Assistant
I recently bought the White Series (Thread/Matter) Smart Dimmer and have been using it with Home Assistant, where it works really well. However, I have a couple of questions I haven’t been able to figure out:
  1. How can I change the LED color through an automation? For example, I’d like the LED to turn red if the garage door is open.
  2. How do I trigger an automation when the config button is pressed twice? I see an option to trigger when the config button is pressed, but I want it to activate only on a double press.
Did you download the multi-tap blueprint in HA yet???
No could you please share a link for it?
