Diagram + Confusion about 3 way replacement (with neutral)
So I just replaced an old analog dimmer (which is attached to about 6 LEDs) with an inovelli switch and I’m having some issues.
As it stands the Dumb switch controls the lights on / off (only) and the inovelli is able to dim them “somewhat” (which makes me think I might need a bypass). I’m using Home Assistant and ZwaveJS to MQTT and use the interface there to change the various settings on the switch to try to get it to function properly.
What I did was try the combos of inovelli on/off and dumb switch on/off and take the voltage at all the different points to see if maybe I wired something wrong or if anybody can offer some help.
Red Dimmer On / Dumb On - LIGHTS ON
Traveler:Load = 56
Traveler:Line = 53
Load:Line = 16
Neutral:Traveler = 1
Netural:Load = 120
Netural:Line = 120
A:B = 53
A:C = 0
B:C = 53
Red Dimmer Off / Dumb On - LIGHTS SLIGHTLY DIM
Traveler:Load = 59
Traveler:Line = 27
Load:Line = 58
Neutral:Traveler = 0
Netural:Load = 120
Netural:Line = 0
A:B = 31
A:C = 0
B:C = 0
When the red dimmer is off → I do see a dimming on the lights but they do not turn off (I assume I need to install a bypass I guess… and/or I should have taken the voltage across the LED lights - but there are 6 of them so this is throwing me off
Red Dimmer On / Dumb Off - LIGHTS OFF
Traveler:Load = 120
Traveler:Line = 120
Load:Line = 19
Neutral:Traveler = 2
Netural:Load = 120
Netural:Line = 120
A:B = 0
A:C = 120
B:C = 120
Red Dimmer Off / Dumb Off - LIGHTS OFF
Traveler:Load = 120
Traveler:Line = 16
Load:Line = 108
Netural:Load = 120
Netural:Line = 0
A:B = 0
A:C = 19
B:C = 19
So if anybody can offer some assistance I’d be real appreciative. I’m not super smart about wiring (obviously) but I’m hoping there is enough info here to make some progress.
Thanks
Here is what I currently have set in ZwaveJS/MQTT:
Oh-> Also there was no neutral in the mix before hand. I found one in the wall and wired it in
You’re going to have to pull everything out of the box (leave the bundles intact) and then post pictures so that we can see into the box as well. Not only do we want to see the connections to the switches, we want to see the number of cables coming into the boxes.
Do you have pictures of how the original dimmer was wired before you replaced it with the Inovelli?
Ok, thx. So we’ll call that last pic in the middle the “Left” box, the one close to the moulding.
Now the other box. Same thing with everything pulled out.
Here is the dumb switch box. Sorry I’m doing this on my phone.
So in the “right” dumb switch box, how many Romexs are coming into the box? I see a 3-wire at the top left, which will be from the other switch. But in the top right, which I can’t see well since they’re not pulled out, it looks like two 2-wire Romexs? Is that correct?
I would ordinarily expect to see one, not two 2-wires. What are these switches controlling? Are there lights in two locations?
You’re going to have to pull that stuff on the right out. I’m I see the whites bundled on the right, but is there a black bundle behind it. I’m looking to see where the conductor that is connected to the black screw on the switch (which I also can’t see) is going. Is that the black conductor that is wound around the other two?
I’ll get a “correct” set of pics out shortly :slight_smile:
Was this neutral from the same circuit?
I think he means he grabbed it from the neutral bundle in the box. I thought the same thing at first.
Ahhh :ok_hand:
Ok I’m sitting at my computer and I think I took some better pictures (I think).
I put everything back together again. And here are some annotated pictures.
The Left Switch which is the existing 600W incandescent only dimmer is shown here.
Inside the box are two bundles of wires/Romex/Something
The right one (which I think comes from the garage)
has 3 wires
Here is a detailed view (Looks like Netural/Grond/Power) - possibly coming across two different “wires” on a single pull
This is the switch I wanted to put inovelli in.’
Next we have the non-dimmer switch - which if everything gets installed will be the dumb switch
When looking at how the actual switch is wired → the Red&Black from the left plug into the copper terminals on the switch
The black screw runs off to the right side … which I assume goes into the lights themselves…
I tried to write a diagram of what I think I’m seeing here.
I mean off hand it looks right. Have you tried configuring the switch locally instead of through HA? Bypass is probably necessary for sure.
The first box, the BLK line, is it coming out of the same Romex as the WHT neutral bundle you suspect? I see two ROmex. I assume one is going to an outlet.
I’m unaware of any outlets on the same circuit - but I guess I could pull the breaker and go poking around.
I’m confused about why I need a bypass because there are 7 LEDs on the circuit. Its incandescent CAN’s retrofitted into LEDs… :man_shrugging:
Some LEDs regardless of wattage will sometimes require a bypass if you notice dim lights from the fixture if the switch is off. Not always but sometimes. Now if I’m reading your sentence correctly you installed incandescent lights in the LED can? Or LEDs retrofit into older incandescent cans?
What @harjms said.
Looks fine to me too. I thought I saw 2 2-wires in the dumb switch box, but with the extended I see that’s not the case.
Just to confirm in the Inovelli box, the line and neutral should be coming from the black and white bundles. The load and traveler on the Inovelli should be the black and red on the 3-wire. I think it’s correct, just confirming.
Looks to be a straightforward line/load in separate boxes.
So looking at the wiring diagram that I think meets what I have - looks like I actually need to change how the black wire in the 1st box is wired.
https://desk.zoho.com/DocsDisplay?zgId=691830694&mode=inline&blockId=k4wwh08a2d8d608d24e718b6a6748c0d0b750
It the picture on the left it looks like the incoming black is jumped to the 2nd box
Where as in the picture on the right the incoming black goes into line and isn’t jumped…
Am I reading that correctly? If that’s the case I may need to change how all the wires are spliced together in the existing dimmer box.
(unless I read this wrong)
Incorrect drawing. You have this:
