Dimmer Feedback Home Assistant
I’m using Blue series switches but I imagine this would be the same for Red as well.
I use Home Assistant and am using the Adaptive Lighting plugin. It works exactly how I want it to however, the feedback LED bar on the switch does not reflect the current brightness.
What do I need to do to get the feedback bar to update after each time there is a change to the brightness of the lights?
The adaptive brightness plugin is changing the brightness on the fly so it could change multiple times after the initial on state.
The lights are setup in a group and the group is bound to the switch via the level control attribute.
By any chance have you set any notifications on the LED bar? It its active, it will override the the display of brightness level.
Also check your setting for Parameter 17 which controls how the led bar when the level is adjusted
17. Load Level Indicator Timeout
Shows the level that the load is at for x number of seconds after the load is adjusted and then returns to the Default LED state.
Something isn’t right in your config/setup. I use adaptive lighting and it perfectly dims the LED bar and the lights over time.
You included the light entity that is attached to the dimmer into the AL config?
I’ve included the light group but not the switch light entity. Should I include the switch as well?
Yes, I’ve found AL is happier with individual entities than groups. I have all impacted entities in specific integrations of AL for each sub-system (like bedrooms, main floor, etc.)
See I’ve had the opposite experience. If I bring the individual bulb entities into the AL configuration the lights do crazy things. By bringing in the group it works perfectly.
My question Moreso is do I need to bring in the group and the switch?
Or are you saying don’t do the lights at all and instead bring in only the switch?
Edit
I tried removing the group of lights and replacing it with the switch. This works except the color temp doesn’t adjust.
I currently have the switch bound to the group of lights via the LevelControl attribute. Does this only turn the lights on and to a brightness level but not adjust color?
Correct, the switch can only control bulb brightness and not bulb color temp.
Although I wonder if this is something that could be done via future firmware when the switch is in Smart Bulb Mode.
@MRobi Does that mean there is no way to press the Blue Series smart switch and have it apply Adaptive Lighting settings for brightness and color temperature? Right now, this only works for me when I make the light turn on call from Home Assistant targeting the group of lights, but not from the switch (it always applies the same brightness and color temperature regardless of time of day). In Adaptive Lighting, I’ve tried targeting the light switch, the entity I created using Zigbee binding, and a separate light group that I created in my config).
How do you have your adaptive lighting setup? I’m thinking check your initial transition setting. It may be working, but if the initial transition setting is set to 90s then it’ll take a long time to adapt.
The default transition time is 45 seconds. I had changed to 120 seconds based on another thread that said a transition time longer than the interval time was helpful if lights were not adapting as expected. I’ll switch back to 45 seconds and see how it goes. Thank you.
Targeting the lights themselves never cause a corresponding change in the switch led as the switch doesn’t go out and look at the led state as far as I know.
The way I handled this was putting the switch and the lights all into one zigbee group and targeting that from adaptive lighting. Coincidentally, this group is also what I target in my home assistant dashboard. Any time you target the lights and want the switch to match, you have to send the command to the switch as well.
I stopped using adaptive lighting because I kept having issues with the lights flickering on when off, but I think this was unrelated to this setup.
Is that also the same group that you bind to the LevelControl and OnOff clusters on the switch? Or are you not using bindings?
I’m still binding each switch to the group using level control and onoff
