Dimmer with smart bulb
This question is kindergarten compared to what you guys are trying.
I have 8 gu10 bulbs set up with an Inovelli Black dimmer. I want to exchange 2 gu10s with 2 zigbee gu10s.
At this stage in my learning curve Im fine using Google assistant or SmartThings to control the 2 smart bulbs… and keep the other 6 gu10s on the Black dimmer.
Can that work? I may connect the switch when I’m farther along the learning curve. I don’t even mind of the dumb switch has to stay in the on position to make the smart bulbs work.
It’s a neutral wire a 3 way switch with a 2nd gen black dimmer and dumb switch at the end.
Thanks.
I also have some red dimmers that I could exchange with the black if needed.
