Dimming via HA doesn't sync with LED bar
I have several Blue Series 2-1s binded to Hue bulbs in HA via ZHA. It all works well except when dimming via HA.
If I dim the switch via HA to 50%, it does dim the bulbs however the LED bar on the switch remains at 100%. If I use the switch itself to dim, then the LED bar changes accordingly.
Is there something I need to in HA to make the sure the LED bar reflects the dim level when dimmed via HA?
Are you sure you are dimming the actual switch via HA and not the bulb or bulb group? I have only experienced this if I dimmed it directly on the bulb
