I recently installed my Red series switch as a single switch in a room. The switch usually controls a couple outlets, but I am wanting to use it to control 3 Z-Wave lights (RGB Yeelights). I can program the switch fine within Hubitat, but for some reason I cannot disable the internal relay… I’ve tried doing it manually (pressing config button 8 times) and disabling it within Hubitat. Seems no matter what I do pressing the switch off cuts off power to the outlets/switch…
Ideally I want power always on through the switch (to the outlets) and only use the switch to toggle actions via Hubitat. Not sure if I wired something wrong or what - though everything works correctly otherwise…
Appreciate any help! Thanks!
(I followed the install instructions from Inovelli and am using their driver via Github.)
