Duplicate instance of Red Series Dimmer in SmartThings
Hello,
My Dimmer was correctly set up in SmartThings and is functioning normally, however I have an additional unassigned Inovelli Red Series Dimmer device that keeps popping up in my app. When I check the IDE I see it there as well with a Zigbee address. Deleting it from both the app and the IDE do no good whatsoever because it comes right back. In the hub’s event log, I can see that the switch is continually rejoining the hub via an event beginning “zbjoin:”. The network address for this instance is different than the functioning device but remains the same. I have factory reset the device, excluded it, air gapped it and re-installed it. The issue persists. Any ideas? Thanks.
EZ
