Ecosmart Bulbs Flickering
Back in February I added Ecosmart bulbs and they seemed to work pretty well but recently some of them would flicker. I thought the bulbs were going bad so installed new Ecosmart bulbs and they would start flickering too after a short while. I can adjust the brightness to 100% and it seems to be ok for awhile but then will start flickering.** Firmware: 1.57. The internet mentioned turning Parameter
51 (Button Delay) off but that didn’t help. Is my switch going bad?
You didn’t specify which red dimmer you’re referring to, but based on the firmware I’m guessing a Gen 2 LZW31-SN?
There have been a number of firmware releases post 1.57. It might not hurt to upgrade.
