Error Installing LZW42 RGBW Bulb Device Handler
I get an error message when I try to install the device handler. Any advice?
“Org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed: script_dth_metadata_f9ae8952_0c3e_4a0d_8d5c_e41da86abfa5: 579: unexpected token: * @ line 579, column 2. * Removed SmartThings related code ^ 1 error”
Ofer
I had to go on gethub and get the previous handler to get it to work.
Thank you! This one worked, although it doesn’t seem to change much from the RGBW Light device type (unless I’m missing something).
Thanks again!
No prob,
I honestly don’t really think it makes much of a difference but it does seem to give a little more control over the device.
@eric getting the same error code as mentioned above following posted instructions on Inovelli web site.
Going to try this one now.
Just thought I would help confirm error
Hey guys – sorry about this! Can you let me know what pages you were at?
I fixed the following ones:
Thanks for pointing this out!
