My fan and light only has black, white, blue, and ground and I’m not sure how to connect my Blue Fan/Canopy Module and Dimmer Switch Combo.
Unfortunately, I am not sure what the make/model of my fan is, but there does not appear to be a separate wire for the fan motor. It’s possible it’s designed to only work with the switch, which is not a standard switch that I’ve ever seen.
The switch is a MinkaAire, it’s single gang sized, and has a dimmer for the light as well as a speed control for the fan.
Here’s the wiring diagram of the switch
And the front of the switch
edit: I think this might be the manual for the fan/light. https://www.minkagroup.net/images/instruction-manuals/F522L-English.pdf
It definitely shows black is the fan motor, blue is the light, white is neutral, green is ground.
So are the Inovelli modules compatible with my fan?
