I’d like to create a trigger based on pressing the favorite button using ZHA / Home Assistant. When pressing the up paddle or down paddle I see a state_change event fired, but I don’t see anything happen for the favorite button. Is there a setting that needs to be configured to get this to happen?
This is with the blue series light switch, but you should get a log hit for when you hit the config button (It looks like this is referred to as the configuration/favorites button in some of the fan docs.
This is how you would use it in an automation:
