Firmware v1.41 (Beta) | LZW31-SN | Dimmer - Red Series (Gen 2)
Hey @EricM_Inovelli I noticed this morning that the dimmer I have been having problems with (the one that cuts off power even on 1.44) is buzzing quite noticeably. I may try swapping out a different dimmer and see if it does the same thing on that lighting circuit.
Any new developments on OTA updates via Hubitat? I’ve got unresponsive LED’s on my dimmers and a new C7. (Also have my old C5 connected to a range extender in my garage and working to do the whole master/slave setup but accidentally did v1 instead of v2 so I have to redo that mess).
Hey @Cebby, welcome to the community! Yes, there is now the ability to update your devices via OTA on Hubitat :slight_smile:
Hopefully this should fix my issues (just waiting on my USB stick for updates). Switch kept going unresponsive/stuck with notifications before. I’ve re-done the setup and without notifications and it’s working properly.
Thank you!!! SILabs website has changed and I couldn’t find anything but the Simplicity Studio, which confused me. The help file should be updated so people can get this file.
EDIT: Use this:
https://siliconlabs.force.com/s/validatezwsdk?ContentType=SDK&rURL=https%3A%2F%2Fwww.silabs.com%2Fproducts%2Fdevelopment-tools%2Fsoftware%2Fz-wave%2Fembedded-sdk.html&ContentId=0681M000006WUzV+
Yep, Silabs’ site is confusing. I think you are in the correct area, though. The link I have takes me to the downloads for the Simplicity Studio, which is what I think you found. At the time, I commented to someone that I had to sownload the SDK first and then it let me install 5.39 of the PC Controller. You want to use that version.
