I’ve run into a problem with both v1.57 and v1.61. Previously I was running v1.52, and I could set parameter 5 (Minimum Dim Level) on several of our lights in our house. So that when you dim the light, it doesn’t turn off the light at the lowest level. After upgrading to 1.57 or later, now even if I set parameter 5 to the highest value of 45, the light still turns off when I dim it down all the way. It seems like the parameter 5 is working, but not as sensitive as it used to be.
I find this creates a bit of a usability problem, as people/kids will think the switch is off, even though it is just dimmed all the way down. Because they don’t look at the led status on the dimmer.
I guess I will downgrade to 1.52 again, or maybe 1.48.
