"Generic Component RGBW" with a namespace of hubitat?
Hey all -
I’m having an issue with Hubitat after replacing my hub; I reset and re-paired all of my Inovelli switches (LZW30, LZW31, LZW36, and VZM35s, about two dozen of them) and they all seem to have lost the ability to create the LED child devices.
This all worked perfectly before I migrated hubs, but now when I toggle the “Create LED Child Device” on and off this is what I see in the event log:
Child device creation failed. Make sure the driver for "Generic Component RGBW" with a namespace of hubitat is installed
I can see that the Generic Component RGBW driver is available in the system, I can select it as the device type for any device I like. It’s built in and not user-loaded so I assume that means it’s the Hubitat namespace. What am I missing here?
I figured it out. This driver error was a red herring; the real issue were “phantom” child devices which were conflicting - I had to go through a ton of trouble to locate and remove them all manually, then toggle the “create child device” switch on and off, and they showed up. For more details, check out Apps show removed devices (NOT ghost z-wave devices) - #7 by jonnyborbs - Apps - Hubitat
