I have installed some 4 way Red Dimmers yesterday and now am working on the grouping to get them to Sync using Home Assistant.
I was able to successfully get my 3way working correctly by changing the zwave hub association to disabled in Zwavejs to MQTT in Home Assistant and then by grouping both switches together.
On my 4 way setups using all Red Dimmers, I am not having much luck. Do I need to create a group entry for each switch that contains all other switches, or just add the load switch as an entry under each? Any other parameters that need modified?
So I have created groups within Zwavejs to MQTT and the non load controlling switches to the load controlling switch. I also disabled the association zwave hub behavior parameter on both non load controlling switches.
Now the load controlling switch works fine however the other two are painfully slow to turn the lights on or off ( 20 seconds or more some times, and the LED bar sync is hit or miss. Usually just works on the load switch and one other, but not the third. Is there another parameter I’m missing?
I should add that these are red dimmers that I’m trying to use as on/off switches. My zwave network is small so far with 10 nodes and are all within 15 ft of my controller.
