Yes that does makes sense. Both switches control a light at the top of the stairs and then 2 cans at the bottom. I will do the voltage test when I get a chance today. Anything else I should test before I put the wires back?
No, that should be it. I just want to insure we know which box has the constant hot. After that it’s just a diagram.
Which box do you want the dimmer in?
Sorry for the crude picture but each of these lights are grouped together. And I am thinking that I’d like each group to have a dimmer (like they currently do). It would be the 3 light switches on the right side of the group.
I also would defer to you on a recommendation.
120 volts was right on when I just tested.
Halos are not on the list as compatible or not compatible. Hopefully someone here has them and can comment.
Ok, we need to be specific. I asked you to test two locations. To which are you referring?
So thus far we’ve been working on the dimmer only. The other switch legs (the 3 to the right) are all non-neutrals. You can use an Inovelli dimmer there, but with just a couple LEDs on each, you would more than likely need a bypass. Typically the bypass is installed at the light, which might be a problem. You can try the bypass at the switch with no guarantees.
The non-neutral with inaccessible LED cans might be a problem. You won’t know until you try it. The good news is that since they are 2-ways, the installation is simple.
Sorry, the upstairs was 120v and the downstairs was not near that, despite the position of the switch.
I’m not sure I’m following you. Would it make sense for me to replace each of the 3 switches on the right with an inovelli red series?
When you say inaccessible LED cabs what do you mean? Also, could I get a bypass at somewhere like Home Depot?
Right now, we’re working on the 3-way. You have switch at the top of the steps and a switch downstairs. At which of those locations do you want the dimmer?
To wire a bypass properly, it needs to go in the junction box for the light? Are those boxes accessible? Looks like your ceiling is sheetrocked.
I don’t know if HD has bypasses. They are available via Inovelli and other online locations. I’d encourage you to read the forum posts regarding bypasses, brands, installations. There are plenty.
Do I need to put an Inovelli at either of them? Those switches control 3 lights that I don’t necessarily care if they can dim.
We’re still talking about the 3-way. You put the Inovelli in one location and leave the dumb switch in place. If that dumb switch is a dimmer, you will need to replace it with a regular dumb switch or an Aux.
Ok, what I’m asking is, do I need to put an Inovelli on the 3 way?
To clarify, when you say 3 way my understanding of what you mean is this… the 3 way is made up of 2 switches. 1 is on the panel with 2 light switches and is on the right side of that panel (this is a dumb switch). The other is on the panel with 4 light switches and is the farthest to the left (also a dumb switch). These two light switches make up the 3 way. Is that right?
Yep, correct. Just so you know, what you call a panel I call a box, but your understanding is correct.
