Help with Zigbee Bindings
I have Inovelli Blue Dimmers and I want to bind a group of Hue BR30 bulbs with it in ZHA.
I’ve followed the “Group Binding” instructions found here: Setting Up Zigbee Bindings • Home Assistant - ZHA | Inovelli Help Center
I’m running into an issue with Step 12:
"Click on the checkbox that corresponds to, “LevelControl” and, “Endpoint #1” and click, “Bind Group”
There is no Level Control for Endpoint #1 available. There is only Level Control for Endpoint #2 and 3. Any suggestions?
If you want to use the paddle, you’ll want to use Endpoint #2, if you want to use the config button to toggle them on/off or to specific levels instead, you want Endpoint #3.
That worked! Thanks!
