Home Assistant entity doesn't update on repeated actions via zigbee2MQTT
When a button is pressed on the Inovelli switch, the “sensor.switch_action” button updates in HA, but if the same action is sent consecutively (i.e. config_single is sent, then config_single is sent again), the action entity does not update in HA, even though the MQTT payload is sent twice.
This causes issues when trying to retrigger automations. Any advice on how to retrigger with repeated values?
I’ve also tried using a device trigger, but that doesn’t seem to work at all.
