I recently moved from ST to Home Assistant and when I migrated one of my NZW31’s over, it’s showing up as “Zooz (Willis Electric) Unknown: type=1f00, id=1f00” instead of an Inovelli NZW31.
I have a different NZW31 on the same system that is showing it’s correct details.
I’ve tried excluding/including it back to HA multiple times. I also excluded it, did a factory reset on the dimmer (10 UP presses) and then re-included it. Still no luck.
It seems to be functioning correctly, I’m just confused why it’s showing up as a Zooz dimmer when it clearly is an Inovelli based on all the markings on the metal and plastic…
