How can I turn off the LED bar?
Unsure how to get the LED bar to turn off forever. Not notifications, just at all.
Tried this and it didn’t work:
“node_id”:“2”,
“parameter”:14,
“value”:0
Are you using the integrated zwave management or zwave2mqtt?
You will need to set parameters 14, 15, and 17 to “0” (assuming we are talking the dimmer LZW31-SN)
I am not using zwave2mqtt.
How do I go about setting those parameters? What service do I call?
I believe your quotes around the 2 in node_id are mistaken and it looks like you are missing spaces
“node_id”: 2,
“parameter”: 14,
“value”: 0
Personally, I just go to the z-wave network management panel, select the node, the select the “node configuration options” I want to change.
http://yoururl:8123/config/zwave
What does it mean when we only have two parameters to configure in the drop down (parameter 1 and 5)?
Have you followed the guide in this post to manually update the zwave config?:
@doublepedaldylan
Hassio usually ignores quotes around integers, but I tried it without (including setting parameters 15 and 17) and nothing changed.
I’m not able to get the dropdowns to appear correctly in my z-wave node management section under :8123/config/zwave. I can select the node, but nothing populates under Node Config Options.
@akifbayram
I didn’t even get that far. Nothing I do makes the Node Config Options dropdown populate.
@doublepedaldylan
Nope. Seems a little messy. Why is that necessary and what do I gain from it?
I think you can also change those settings from the switch itself if needed:
Red Series dimmer (LZW31-SN) instruction manual, page 9. Parameters 14, 15, and possibly 17:
For whatever reason, the switch I want the indicator off on does not ever flash yellow. My others do.
