Hubitat and Blue Series mmWave & Lux Pairs and then no response
I just received my Blue mmWave switches today. I decided to test one out in my Office where I have 4 LED ceiling lights. I installed the latest driver on the Hubitat from your github. Went into paring mode, waited for Hubitat to state ready to pair turned on power to the switch and the blue pulsing started and the Hubitat recognized and paired and applied your driver to the device.
Logs showed data from teh swich such as RSSI and Lux etc. Then nothing else. I tried to control the switch from the Hubitat the logs show the the on or off command but no responses from the switch
I pulled the airgap at the bottom of the paddle and the switch went back into pulsing blue which means it was in paring mode again. I was able to repeat the pairing only not to have control again and this time removed all power by breaker and then re-applied, re-paird and same issue no logs after setup and no control.
Is the issue with the Hubitat or the switch any help would be appreciated.
I have the exact same issue.
I’m using Hubitat C8 Pro. If I start Zigbee pairing again in Hubitat, it will reconnect the switch (automatically) and it work with Hubitat for a couple minutes before it goes back to the flashing blue LED indicating it has reentered pairing mode.
@dst.graham @RonV42 I would factory reset the switch and start the pairing process and when the LED bar turns green (as soon as it turns green) pull the air gap for about 15 seconds. Push the air gap back in and then go to the device and click configure and initialize. Give it a few then test the switch for functionality. Let me know how it goes.
Yes I did that pull airgap after green, waited 15 seconds and pushed it back it. I was able to get “one way communcation with the switch, hub would be able to send commands to turn off/on but no reports back from switch with lux or if the switch was manually turned off or on. Then I noticed something interesting when I went though my logs this morning. A second “rebind” to the network/hub seemed to happen and then the lux started to show up and other paremeters were being filled on a 10 minute interval. Still not seeing manual switch event but now receivng lux as the room lighting changes and on the 10 minute cycle.
Here is the logs from when I did the switch pairing with the airgap method, 3:47 was the time of pairing, but the logs show that 4:03 it may have re-inialiized itself and then at 4:20 you can see parameters were sent to the switch from the driver. After that lux started to report. Interesting because after 3:47 and some command tests and that pairing I left it alone overnight. Maybe it takes 30 minutes or more or something with the binding the Zigbee is blocking and it’s internal “rebind” fixed it.
One thing for sure is I am not getting manual switch events when I tested this morning.
dev:16372025-12-19 04:20:33.943 PMtraceinovelli blue ILLUMINANCE_MEASUREMENT_CLUSTER (cluster:0400 data:[00])
dev:16372025-12-19 04:20:33.940 PMtraceinovelli blue parse(catchall: 0104 0400 01 01 0040 00 89EE 00 00 0000 07 01 00)
dev:16372025-12-19 04:20:31.932 PMinfoinovelli blue Dimming Method = Leading Edge
dev:16372025-12-19 04:20:31.931 PMinfoinovelli blue P258=0 (Dimmer mode) [Param:258 Value:0 Default:1]
dev:16372025-12-19 04:20:31.927 PMtraceinovelli blue Private Cluster (cluster:FC31 attr:0102 value:00)
dev:16372025-12-19 04:20:31.925 PMtraceinovelli blue parse(read attr - raw: 89EE01FC310A02011000, dni: 89EE, endpoint: 01, cluster: FC31, size: 0A, attrId: 0102, encoding: 10, command: 01, value: 00)
dev:16372025-12-19 04:20:31.878 PMtraceinovelli blue Private Cluster (cluster:FC31 data:[00])
dev:16372025-12-19 04:20:31.876 PMtraceinovelli blue parse(catchall: 0104 FC31 01 01 0040 00 89EE 00 01 122F 04 01 00)
dev:16372025-12-19 04:20:31.784 PMinfoinovelli blue P52=0 (SBM disabled)) [Param:52 Value:0 Default:0]
dev:16372025-12-19 04:20:31.781 PMtraceinovelli blue Private Cluster (cluster:FC31 attr:0034 value:00)
dev:16372025-12-19 04:20:31.778 PMtraceinovelli blue parse(read attr - raw: 89EE01FC310A34001000, dni: 89EE, endpoint: 01, cluster: FC31, size: 0A, attrId: 0034, encoding: 10, command: 01, value: 00)
dev:16372025-12-19 04:20:31.731 PMtraceinovelli blue Private Cluster (cluster:FC31 data:[00])
dev:16372025-12-19 04:20:31.730 PMtraceinovelli blue parse(catchall: 0104 FC31 01 01 0040 00 89EE 00 01 122F 04 01 00)
dev:16372025-12-19 04:20:31.683 PMinfoinovelli blue cleared P50 since it is the default
dev:16372025-12-19 04:20:31.680 PMinfoinovelli blue P50=5 (500ms Button Delay) [Param:50 Value:5 Default:5]
dev:16372025-12-19 04:20:31.678 PMtraceinovelli blue Private Cluster (cluster:FC31 attr:0032 value:05)
dev:16372025-12-19 04:20:31.676 PMtraceinovelli blue parse(read attr - raw: 89EE01FC310A32002005, dni: 89EE, endpoint: 01, cluster: FC31, size: 0A, attrId: 0032, encoding: 20, command: 01, value: 05)
dev:16372025-12-19 04:20:31.627 PMtraceinovelli blue Private Cluster (cluster:FC31 data:[00])
dev:16372025-12-19 04:20:31.626 PMtraceinovelli blue parse(catchall: 0104 FC31 01 01 0040 00 89EE 00 01 122F 04 01 00)
dev:16372025-12-19 04:20:31.534 PMinfoinovelli blue cleared P34 since it is the default
dev:16372025-12-19 04:20:31.530 PMinfoinovelli blue P34=2 [0x02] Undefined Parameter 34 [Param:34 Value:2 Default:2]
dev:16372025-12-19 04:20:31.524 PMtraceinovelli blue Private Cluster (cluster:FC31 attr:0022 value:02)
dev:16372025-12-19 04:20:31.522 PMtraceinovelli blue parse(read attr - raw: 89EE01FC310A22002002, dni: 89EE, endpoint: 01, cluster: FC31, size: 0A, attrId: 0022, encoding: 20, command: 01, value: 02)
dev:16372025-12-19 04:20:31.473 PMtraceinovelli blue Private Cluster (cluster:FC31 data:[00])
dev:16372025-12-19 04:20:31.471 PMtraceinovelli blue parse(catchall: 0104 FC31 01 01 0040 00 89EE 00 01 122F 04 01 00)
dev:16372025-12-19 04:20:31.424 PMtraceinovelli blue Private Cluster (cluster:FC31 data:[00])
dev:16372025-12-19 04:20:31.422 PMtraceinovelli blue parse(catchall: 0104 FC31 01 01 0040 00 89EE 00 01 122F 04 01 00)
dev:16372025-12-19 04:20:31.389 PMinfoinovelli blue Dimming Method = Trailing Edge
dev:16372025-12-19 04:20:31.387 PMinfoinovelli blue P22=1 (Dumb 3-way) [Param:22 Value:1 Default:0]
dev:16372025-12-19 04:20:31.385 PMtraceinovelli blue Private Cluster (cluster:FC31 attr:0016 value:01)
dev:16372025-12-19 04:20:31.382 PMtraceinovelli blue parse(read attr - raw: 89EE01FC310A16002001, dni: 89EE, endpoint: 01, cluster: FC31, size: 0A, attrId: 0016, encoding: 20, command: 01, value: 01)
dev:16372025-12-19 04:20:31.279 PMinfoinovelli blue cleared P20 since it is the default
dev:16372025-12-19 04:20:31.275 PMinfoinovelli blue P20=10 (Active Energy Report 0.1kWh change) [Param:20 Value:10 Default:10]
dev:16372025-12-19 04:20:31.273 PMtraceinovelli blue Private Cluster (cluster:FC31 attr:0014 value:000A)
dev:16372025-12-19 04:20:31.270 PMtraceinovelli blue parse(read attr - raw: 89EE01FC310C1400210A00, dni: 89EE, endpoint: 01, cluster: FC31, size: 0C, attrId: 0014, encoding: 21, command: 01, value: 0A00)
dev:16372025-12-19 04:20:31.230 PMtraceinovelli blue Private Cluster (cluster:FC31 data:[00])
dev:16372025-12-19 04:20:31.228 PMtraceinovelli blue parse(catchall: 0104 FC31 01 01 0040 00 89EE 00 01 122F 04 01 00)
dev:16372025-12-19 04:20:31.183 PMinfoinovelli blue cleared P19 since it is the default
dev:16372025-12-19 04:20:31.179 PMinfoinovelli blue P19=3600s (Periodic Power/Energy ) [Param:19 Value:3600 Default:3600]
dev:16372025-12-19 04:20:31.177 PMtraceinovelli blue Private Cluster (cluster:FC31 attr:0013 value:0E10)
dev:16372025-12-19 04:20:31.174 PMtraceinovelli blue parse(read attr - raw: 89EE01FC310C130021100E, dni: 89EE, endpoint: 01, cluster: FC31, size: 0C, attrId: 0013, encoding: 21, command: 01, value: 100E)
dev:16372025-12-19 04:20:31.130 PMtraceinovelli blue Private Cluster (cluster:FC31 data:[00])
dev:16372025-12-19 04:20:31.128 PMtraceinovelli blue parse(catchall: 0104 FC31 01 01 0040 00 89EE 00 01 122F 04 01 00)
dev:16372025-12-19 04:20:31.077 PMinfoinovelli blue cleared P18 since it is the default
dev:16372025-12-19 04:20:31.074 PMinfoinovelli blue P18=10 (Active Power Report 10% change) [Param:18 Value:10 Default:10]
dev:16372025-12-19 04:20:31.072 PMtraceinovelli blue Private Cluster (cluster:FC31 attr:0012 value:0A)
dev:16372025-12-19 04:20:31.070 PMtraceinovelli blue parse(read attr - raw: 89EE01FC310A1200200A, dni: 89EE, endpoint: 01, cluster: FC31, size: 0A, attrId: 0012, encoding: 20, command: 01, value: 0A)
dev:16372025-12-19 04:20:31.024 PMtraceinovelli blue Private Cluster (cluster:FC31 data:[00])
dev:16372025-12-19 04:20:31.022 PMtraceinovelli blue parse(catchall: 0104 FC31 01 01 0040 00 89EE 00 01 122F 04 01 00)
dev:16372025-12-19 04:20:30.979 PMinfoinovelli blue cleared P15 since it is the default
dev:16372025-12-19 04:20:30.975 PMinfoinovelli blue P15=101 (power-on level 101%) [Param:15 Value:101 Default:101]
dev:16372025-12-19 04:20:30.972 PMtraceinovelli blue Private Cluster (cluster:FC31 attr:000F value:FF)
dev:16372025-12-19 04:20:30.970 PMtraceinovelli blue parse(read attr - raw: 89EE01FC310A0F0020FF, dni: 89EE, endpoint: 01, cluster: FC31, size: 0A, attrId: 000F, encoding: 20, command: 01, value: FF)
dev:16372025-12-19 04:20:30.869 PMtraceinovelli blue Private Cluster (cluster:FC31 data:[00])
dev:16372025-12-19 04:20:30.867 PMtraceinovelli blue parse(catchall: 0104 FC31 01 01 0040 00 89EE 00 01 122F 04 01 00)
dev:16372025-12-19 04:20:30.827 PMinfoinovelli blue P14=90 (default remote level 90%) [Param:14 Value:90 Default:101]
dev:16372025-12-19 04:20:30.825 PMtraceinovelli blue Private Cluster (cluster:FC31 attr:000E value:E5)
dev:16372025-12-19 04:20:30.822 PMtraceinovelli blue parse(read attr - raw: 89EE01FC310A0E0020E5, dni: 89EE, endpoint: 01, cluster: FC31, size: 0A, attrId: 000E, encoding: 20, command: 01, value: E5)
dev:16372025-12-19 04:20:30.772 PMtraceinovelli blue Private Cluster (cluster:FC31 data:[00])
dev:16372025-12-19 04:20:30.770 PMtraceinovelli blue parse(catchall: 0104 FC31 01 01 0040 00 89EE 00 01 122F 04 01 00)
dev:16372025-12-19 04:20:30.724 PMinfoinovelli blue P13=90 (default local level 90%) [Param:13 Value:90 Default:101]
dev:16372025-12-19 04:20:30.721 PMtraceinovelli blue Private Cluster (cluster:FC31 attr:000D value:E5)
dev:16372025-12-19 04:20:30.718 PMtraceinovelli blue parse(read attr - raw: 89EE01FC310A0D0020E5, dni: 89EE, endpoint: 01, cluster: FC31, size: 0A, attrId: 000D, encoding: 20, command: 01, value: E5)
dev:16372025-12-19 04:20:30.677 PMtraceinovelli blue Private Cluster (cluster:FC31 data:[00])
dev:16372025-12-19 04:20:30.675 PMtraceinovelli blue parse(catchall: 0104 FC31 01 01 0040 00 89EE 00 01 122F 04 01 00)
dev:16372025-12-19 04:20:30.602 PMtraceinovelli blue Private Cluster (cluster:FC31 data:[00])
dev:16372025-12-19 04:20:30.601 PMtraceinovelli blue parse(catchall: 0104 FC31 01 01 0040 00 89EE 00 01 122F 04 01 00)
dev:16372025-12-19 04:20:30.559 PMinfoinovelli blue P10=101 (max level 101%) [Param:10 Value:101 Default:100]
dev:16372025-12-19 04:20:30.557 PMtraceinovelli blue Private Cluster (cluster:FC31 attr:000A value:FF)
dev:16372025-12-19 04:20:30.554 PMtraceinovelli blue parse(read attr - raw: 89EE01FC310A0A0020FF, dni: 89EE, endpoint: 01, cluster: FC31, size: 0A, attrId: 000A, encoding: 20, command: 01, value: FF)
dev:16372025-12-19 04:20:30.512 PMtraceinovelli blue Private Cluster (cluster:FC31 data:[00])
dev:16372025-12-19 04:20:30.510 PMtraceinovelli blue parse(catchall: 0104 FC31 01 01 0040 00 89EE 00 01 122F 04 01 00)
dev:16372025-12-19 04:20:30.412 PMinfoinovelli blue cleared P12 since it is the default
dev:16372025-12-19 04:20:30.408 PMinfoinovelli blue P12=0 (Auto Off Timer disabled) [Param:12 Value:0 Default:0]
dev:16372025-12-19 04:20:30.406 PMtraceinovelli blue Private Cluster (cluster:FC31 attr:000C value:0000)
dev:16372025-12-19 04:20:30.404 PMtraceinovelli blue parse(read attr - raw: 89EE01FC310C0C00210000, dni: 89EE, endpoint: 01, cluster: FC31, size: 0C, attrId: 000C, encoding: 21, command: 01, value: 0000)
dev:16372025-12-19 04:20:30.356 PMtraceinovelli blue Private Cluster (cluster:FC31 data:[00])
dev:16372025-12-19 04:20:30.354 PMtraceinovelli blue parse(catchall: 0104 FC31 01 01 0040 00 89EE 00 01 122F 04 01 00)
dev:16372025-12-19 04:20:30.309 PMinfoinovelli blue cleared P11 since it is the default
dev:16372025-12-19 04:20:30.305 PMinfoinovelli blue P11=0 (not Inverted) [Param:11 Value:0 Default:0]
dev:16372025-12-19 04:20:30.304 PMtraceinovelli blue Private Cluster (cluster:FC31 attr:000B value:00)
dev:16372025-12-19 04:20:30.301 PMtraceinovelli blue parse(read attr - raw: 89EE01FC310A0B001000, dni: 89EE, endpoint: 01, cluster: FC31, size: 0A, attrId: 000B, encoding: 10, command: 01, value: 00)
dev:16372025-12-19 04:20:30.256 PMtraceinovelli blue Private Cluster (cluster:FC31 data:[00])
dev:16372025-12-19 04:20:30.254 PMtraceinovelli blue parse(catchall: 0104 FC31 01 01 0040 00 89EE 00 01 122F 04 01 00)
dev:16372025-12-19 04:20:30.216 PMinfoinovelli blue cleared P9 since it is the default
dev:16372025-12-19 04:20:30.208 PMinfoinovelli blue P9=1 (min level 1%) [Param:9 Value:1 Default:1]
dev:16372025-12-19 04:20:30.206 PMtraceinovelli blue Private Cluster (cluster:FC31 attr:0009 value:01)
dev:16372025-12-19 04:20:30.204 PMtraceinovelli blue parse(read attr - raw: 89EE01FC310A09002001, dni: 89EE, endpoint: 01, cluster: FC31, size: 0A, attrId: 0009, encoding: 20, command: 01, value: 01)
dev:16372025-12-19 04:20:30.154 PMinfoinovelli blue P8=20 (Local Ramp Rate Off: 2s) [Param:8 Value:20 Default:127]
dev:16372025-12-19 04:20:30.152 PMtraceinovelli blue Private Cluster (cluster:FC31 attr:0008 value:14)
dev:16372025-12-19 04:20:30.150 PMtraceinovelli blue parse(read attr - raw: 89EE01FC310A08002014, dni: 89EE, endpoint: 01, cluster: FC31, size: 0A, attrId: 0008, encoding: 20, command: 01, value: 14)
dev:16372025-12-19 04:20:30.101 PMtraceinovelli blue Private Cluster (cluster:FC31 data:[00])
dev:16372025-12-19 04:20:30.099 PMtraceinovelli blue parse(catchall: 0104 FC31 01 01 0040 00 89EE 00 01 122F 04 01 00)
dev:16372025-12-19 04:20:30.018 PMinfoinovelli blue P7=20 (Remote Ramp Rate Off: 2s) [Param:7 Value:20 Default:127]
dev:16372025-12-19 04:20:30.017 PMtraceinovelli blue Private Cluster (cluster:FC31 attr:0007 value:14)
dev:16372025-12-19 04:20:30.014 PMtraceinovelli blue parse(read attr - raw: 89EE01FC310A07002014, dni: 89EE, endpoint: 01, cluster: FC31, size: 0A, attrId: 0007, encoding: 20, command: 01, value: 14)
dev:16372025-12-19 04:20:29.953 PMtraceinovelli blue Private Cluster (cluster:FC31 data:[00])
dev:16372025-12-19 04:20:29.951 PMtraceinovelli blue parse(catchall: 0104 FC31 01 01 0040 00 89EE 00 01 122F 04 01 00)
dev:16372025-12-19 04:20:29.907 PMinfoinovelli blue P6=20 (Local Dim Rate Down: 2s) [Param:6 Value:20 Default:127]
dev:16372025-12-19 04:20:29.905 PMtraceinovelli blue Private Cluster (cluster:FC31 attr:0006 value:14)
dev:16372025-12-19 04:20:29.903 PMtraceinovelli blue parse(read attr - raw: 89EE01FC310A06002014, dni: 89EE, endpoint: 01, cluster: FC31, size: 0A, attrId: 0006, encoding: 20, command: 01, value: 14)
dev:16372025-12-19 04:20:29.854 PMtraceinovelli blue Private Cluster (cluster:FC31 data:[00])
dev:16372025-12-19 04:20:29.852 PMtraceinovelli blue parse(catchall: 0104 FC31 01 01 0040 00 89EE 00 01 122F 04 01 00)
dev:16372025-12-19 04:20:29.805 PMinfoinovelli blue P5=20 (Remote Dim Rate Down: 2s) [Param:5 Value:20 Default:127]
dev:16372025-12-19 04:20:29.803 PMtraceinovelli blue Private Cluster (cluster:FC31 attr:0005 value:14)
dev:16372025-12-19 04:20:29.801 PMtraceinovelli blue parse(read attr - raw: 89EE01FC310A05002014, dni: 89EE, endpoint: 01, cluster: FC31, size: 0A, attrId: 0005, encoding: 20, command: 01, value: 14)
dev:16372025-12-19 04:20:29.754 PMtraceinovelli blue Private Cluster (cluster:FC31 data:[00])
dev:16372025-12-19 04:20:29.752 PMtraceinovelli blue parse(catchall: 0104 FC31 01 01 0040 00 89EE 00 01 122F 04 01 00)
dev:16372025-12-19 04:20:29.702 PMinfoinovelli blue P4=20 (Local Ramp Rate On: 2s) [Param:4 Value:20 Default:127]
dev:16372025-12-19 04:20:29.699 PMtraceinovelli blue Private Cluster (cluster:FC31 attr:0004 value:14)
dev:16372025-12-19 04:20:29.695 PMtraceinovelli blue parse(read attr - raw: 89EE01FC310A04002014, dni: 89EE, endpoint: 01, cluster: FC31, size: 0A, attrId: 0004, encoding: 20, command: 01, value: 14)
dev:16372025-12-19 04:20:29.651 PMtraceinovelli blue Private Cluster (cluster:FC31 data:[00])
dev:16372025-12-19 04:20:29.649 PMtraceinovelli blue parse(catchall: 0104 FC31 01 01 0040 00 89EE 00 01 122F 04 01 00)
dev:16372025-12-19 04:20:29.647 PMdebuginovelli blue Debug logging Disabled
dev:16372025-12-19 04:20:29.644 PMtraceinovelli blue Trace logging Enabled
dev:16372025-12-19 04:20:29.642 PMinfoinovelli blue Info logging Enabled
dev:16372025-12-19 04:20:29.632 PMtraceinovelli blue getParameter(258,1000)
dev:16372025-12-19 04:20:29.629 PMtraceinovelli blue Set Private Cluster attribute 258 dataType 0x10 value 0 [delay 1000]
dev:16372025-12-19 04:20:29.628 PMtraceinovelli blue setAttribute(64561, 258, 16, 0, [:], 1000)
dev:16372025-12-19 04:20:29.627 PMtraceinovelli blue calculateSize(1)
dev:16372025-12-19 04:20:29.626 PMtraceinovelli blue setParameter(258, 0, 1)
dev:16372025-12-19 04:20:29.601 PMinfoinovelli blue P3=20 (Remote Ramp Rate On: 2s) [Param:3 Value:20 Default:127]
dev:16372025-12-19 04:20:29.599 PMtraceinovelli blue Private Cluster (cluster:FC31 attr:0003 value:14)
dev:16372025-12-19 04:20:29.596 PMtraceinovelli blue parse(read attr - raw: 89EE01FC310A03002014, dni: 89EE, endpoint: 01, cluster: FC31, size: 0A, attrId: 0003, encoding: 20, command: 01, value: 14)
dev:16372025-12-19 04:20:29.571 PMtraceinovelli blue Private Cluster (cluster:FC31 data:[00])
dev:16372025-12-19 04:20:29.567 PMtraceinovelli blue getParameter(52,1000)
dev:16372025-12-19 04:20:29.565 PMtraceinovelli blue Set Private Cluster attribute 52 dataType 0x10 value 0 [delay 1000]
dev:16372025-12-19 04:20:29.563 PMtraceinovelli blue setAttribute(64561, 52, 16, 0, [:], 1000)
dev:16372025-12-19 04:20:29.562 PMtraceinovelli blue calculateSize(1)
dev:16372025-12-19 04:20:29.561 PMtraceinovelli blue setParameter(52, 0, 1)
dev:16372025-12-19 04:20:29.469 PMinfoinovelli blue P2=20 (Local Dim Rate Up: 2s) [Param:2 Value:20 Default:127]
dev:16372025-12-19 04:20:29.548 PMtraceinovelli blue getParameter(50,333)
dev:16372025-12-19 04:20:29.554 PMtraceinovelli blue parse(catchall: 0104 FC31 01 01 0040 00 89EE 00 01 122F 04 01 00)
dev:16372025-12-19 04:20:29.546 PMtraceinovelli blue Set Private Cluster attribute 50 dataType 0x20 value 5
dev:16372025-12-19 04:20:29.544 PMtraceinovelli blue setAttribute(64561, 50, 32, 5, [:], 333)
dev:16372025-12-19 04:20:29.543 PMtraceinovelli blue calculateSize(8)
dev:16372025-12-19 04:20:29.542 PMtraceinovelli blue setParameter(50, 5, 8)
dev:16372025-12-19 04:20:29.465 PMtraceinovelli blue getParameter(34,333)
dev:16372025-12-19 04:20:29.464 PMtraceinovelli blue Private Cluster (cluster:FC31 attr:0002 value:14)
dev:16372025-12-19 04:20:29.462 PMtraceinovelli blue Set Private Cluster attribute 34 dataType 0x20 value 2
dev:16372025-12-19 04:20:29.461 PMtraceinovelli blue setAttribute(64561, 34, 32, 2, [:], 333)
dev:16372025-12-19 04:20:29.460 PMtraceinovelli blue parse(read attr - raw: 89EE01FC310A02002014, dni: 89EE, endpoint: 01, cluster: FC31, size: 0A, attrId: 0002, encoding: 20, command: 01, value: 14)
dev:16372025-12-19 04:20:29.460 PMtraceinovelli blue calculateSize(8)
dev:16372025-12-19 04:20:29.458 PMtraceinovelli blue setParameter(34, 2, 8)
dev:16372025-12-19 04:20:29.450 PMtraceinovelli blue getParameter(22,333)
dev:16372025-12-19 04:20:29.447 PMtraceinovelli blue Set Private Cluster attribute 22 dataType 0x20 value 0
dev:16372025-12-19 04:20:29.445 PMtraceinovelli blue setAttribute(64561, 22, 32, 0, [:], 333)
dev:16372025-12-19 04:20:29.444 PMtraceinovelli blue calculateSize(8)
dev:16372025-12-19 04:20:29.443 PMtraceinovelli blue setParameter(22, 0, 8)
dev:16372025-12-19 04:20:29.437 PMtraceinovelli blue getParameter(20,333)
dev:16372025-12-19 04:20:29.434 PMtraceinovelli blue Set Private Cluster attribute 20 dataType 0x21 value 10
dev:16372025-12-19 04:20:29.433 PMtraceinovelli blue setAttribute(64561, 20, 33, 10, [:], 333)
dev:16372025-12-19 04:20:29.432 PMtraceinovelli blue calculateSize(16)
dev:16372025-12-19 04:20:29.430 PMtraceinovelli blue setParameter(20, 10, 16)
dev:16372025-12-19 04:20:29.426 PMtraceinovelli blue getParameter(19,333)
dev:16372025-12-19 04:20:29.423 PMtraceinovelli blue Set Private Cluster attribute 19 dataType 0x21 value 3600
dev:16372025-12-19 04:20:29.422 PMtraceinovelli blue setAttribute(64561, 19, 33, 3600, [:], 333)
dev:16372025-12-19 04:20:29.421 PMtraceinovelli blue calculateSize(16)
dev:16372025-12-19 04:20:29.419 PMtraceinovelli blue setParameter(19, 3600, 16)
dev:16372025-12-19 04:20:29.414 PMtraceinovelli blue getParameter(18,333)
dev:16372025-12-19 04:20:29.410 PMtraceinovelli blue Set Private Cluster attribute 18 dataType 0x20 value 10
dev:16372025-12-19 04:20:29.408 PMtraceinovelli blue Private Cluster (cluster:FC31 data:[00])
dev:16372025-12-19 04:20:29.408 PMtraceinovelli blue setAttribute(64561, 18, 32, 10, [:], 333)
dev:16372025-12-19 04:20:29.407 PMtraceinovelli blue calculateSize(8)
dev:16372025-12-19 04:20:29.404 PMtraceinovelli blue parse(catchall: 0104 FC31 01 01 0040 00 89EE 00 01 122F 04 01 00)
dev:16372025-12-19 04:20:29.405 PMtraceinovelli blue setParameter(18, 10, 8)
dev:16372025-12-19 04:20:29.394 PMtraceinovelli blue getParameter(15,333)
dev:16372025-12-19 04:20:29.391 PMtraceinovelli blue Set Private Cluster attribute 15 dataType 0x20 value 255 = 101% on 255 scale
dev:16372025-12-19 04:20:29.389 PMtraceinovelli blue setAttribute(64561, 15, 32, 255, [:], 333)
dev:16372025-12-19 04:20:29.388 PMtraceinovelli blue calculateSize(8)
dev:16372025-12-19 04:20:29.386 PMtraceinovelli blue setParameter(15, 255, 8)
dev:16372025-12-19 04:20:29.380 PMtraceinovelli blue getParameter(14,333)
dev:16372025-12-19 04:20:29.375 PMtraceinovelli blue Set Private Cluster attribute 14 dataType 0x20 value 229 = 90% on 255 scale
dev:16372025-12-19 04:20:29.373 PMtraceinovelli blue setAttribute(64561, 14, 32, 229, [:], 333)
dev:16372025-12-19 04:20:29.372 PMtraceinovelli blue calculateSize(8)
dev:16372025-12-19 04:20:29.370 PMtraceinovelli blue setParameter(14, 229, 8)
dev:16372025-12-19 04:20:29.370 PMinfoinovelli blue P1=20 (Remote Dim Rate Up: 2s) [Param:1 Value:20 Default:25]
dev:16372025-12-19 04:20:29.363 PMtraceinovelli blue Private Cluster (cluster:FC31 attr:0001 value:14)
dev:16372025-12-19 04:20:29.361 PMtraceinovelli blue getParameter(13,333)
dev:16372025-12-19 04:20:29.359 PMtraceinovelli blue parse(read attr - raw: 89EE01FC310A01002014, dni: 89EE, endpoint: 01, cluster: FC31, size: 0A, attrId: 0001, encoding: 20, command: 01, value: 14)
dev:16372025-12-19 04:20:29.358 PMtraceinovelli blue Set Private Cluster attribute 13 dataType 0x20 value 229 = 90% on 255 scale
dev:16372025-12-19 04:20:29.356 PMtraceinovelli blue setAttribute(64561, 13, 32, 229, [:], 333)
dev:16372025-12-19 04:20:29.355 PMtraceinovelli blue calculateSize(8)
dev:16372025-12-19 04:20:29.349 PMtraceinovelli blue setParameter(13, 229, 8)
dev:16372025-12-19 04:20:29.344 PMtraceinovelli blue getParameter(12,333)
dev:16372025-12-19 04:20:29.340 PMtraceinovelli blue Set Private Cluster attribute 12 dataType 0x21 value 0
dev:16372025-12-19 04:20:29.339 PMtraceinovelli blue setAttribute(64561, 12, 33, 0, [:], 333)
dev:16372025-12-19 04:20:29.338 PMtraceinovelli blue calculateSize(16)
dev:16372025-12-19 04:20:29.336 PMtraceinovelli blue setParameter(12, 0, 16)
dev:16372025-12-19 04:20:29.330 PMtraceinovelli blue getParameter(11,333)
dev:16372025-12-19 04:20:29.327 PMtraceinovelli blue Set Private Cluster attribute 11 dataType 0x10 value 0
dev:16372025-12-19 04:20:29.326 PMtraceinovelli blue setAttribute(64561, 11, 16, 0, [:], 333)
dev:16372025-12-19 04:20:29.325 PMtraceinovelli blue Binding Cluster (cluster:8021 data:[AA, 00])
dev:16372025-12-19 04:20:29.325 PMtraceinovelli blue calculateSize(1)
dev:16372025-12-19 04:20:29.324 PMtraceinovelli blue setParameter(11, 0, 1)
dev:16372025-12-19 04:20:29.323 PMtraceinovelli blue Private Cluster (cluster:FC31 data:[00])
dev:16372025-12-19 04:20:29.319 PMtraceinovelli blue getParameter(10,333)
dev:16372025-12-19 04:20:29.318 PMtraceinovelli blue parse(catchall: 0104 FC31 01 01 0040 00 89EE 00 01 122F 04 01 00)
dev:16372025-12-19 04:20:29.316 PMtraceinovelli blue Set Private Cluster attribute 10 dataType 0x20 value 229 = 90% on 255 scale
dev:16372025-12-19 04:20:29.314 PMtraceinovelli blue setAttribute(64561, 10, 32, 229, [:], 333)
dev:16372025-12-19 04:20:29.313 PMtraceinovelli blue calculateSize(8)
dev:16372025-12-19 04:20:29.312 PMtraceinovelli blue setParameter(10, 229, 8)
dev:16372025-12-19 04:20:29.307 PMtraceinovelli blue getParameter(9,333)
dev:16372025-12-19 04:20:29.304 PMtraceinovelli blue Set Private Cluster attribute 9 dataType 0x20 value 25 = 10% on 255 scale
dev:16372025-12-19 04:20:29.301 PMtraceinovelli blue parse(catchall: 0000 8021 00 00 0040 00 89EE 00 00 0000 00 00 AA00)
dev:16372025-12-19 04:20:29.299 PMtraceinovelli blue setAttribute(64561, 9, 32, 25, [:], 333)
dev:16372025-12-19 04:20:29.298 PMtraceinovelli blue calculateSize(8)
dev:16372025-12-19 04:20:29.297 PMtraceinovelli blue setParameter(9, 25, 8)
dev:16372025-12-19 04:20:29.289 PMtraceinovelli blue getParameter(8,333)
dev:16372025-12-19 04:20:29.285 PMtraceinovelli blue Set Private Cluster attribute 8 dataType 0x20 value 20
dev:16372025-12-19 04:20:29.283 PMtraceinovelli blue setAttribute(64561, 8, 32, 20, [:], 333)
dev:16372025-12-19 04:20:29.282 PMtraceinovelli blue calculateSize(8)
dev:16372025-12-19 04:20:29.281 PMtraceinovelli blue setParameter(8, 20, 8)
dev:16372025-12-19 04:20:29.276 PMtraceinovelli blue getParameter(7,333)
dev:16372025-12-19 04:20:29.273 PMtraceinovelli blue Set Private Cluster attribute 7 dataType 0x20 value 20
dev:16372025-12-19 04:20:29.272 PMtraceinovelli blue setAttribute(64561, 7, 32, 20, [:], 333)
dev:16372025-12-19 04:20:29.271 PMtraceinovelli blue calculateSize(8)
dev:16372025-12-19 04:20:29.269 PMtraceinovelli blue setParameter(7, 20, 8)
dev:16372025-12-19 04:20:29.265 PMtraceinovelli blue getParameter(6,333)
dev:16372025-12-19 04:20:29.262 PMtraceinovelli blue Set Private Cluster attribute 6 dataType 0x20 value 20
dev:16372025-12-19 04:20:29.260 PMtraceinovelli blue setAttribute(64561, 6, 32, 20, [:], 333)
dev:16372025-12-19 04:20:29.259 PMtraceinovelli blue calculateSize(8)
dev:16372025-12-19 04:20:29.258 PMtraceinovelli blue setParameter(6, 20, 8)
dev:16372025-12-19 04:20:29.253 PMtraceinovelli blue getParameter(5,333)
dev:16372025-12-19 04:20:29.251 PMtraceinovelli blue Set Private Cluster attribute 5 dataType 0x20 value 20
dev:16372025-12-19 04:20:29.249 PMtraceinovelli blue setAttribute(64561, 5, 32, 20, [:], 333)
dev:16372025-12-19 04:20:29.248 PMtraceinovelli blue calculateSize(8)
dev:16372025-12-19 04:20:29.246 PMtraceinovelli blue setParameter(5, 20, 8)
dev:16372025-12-19 04:20:29.242 PMtraceinovelli blue getParameter(4,333)
dev:16372025-12-19 04:20:29.239 PMtraceinovelli blue Set Private Cluster attribute 4 dataType 0x20 value 20
dev:16372025-12-19 04:20:29.237 PMtraceinovelli blue setAttribute(64561, 4, 32, 20, [:], 333)
dev:16372025-12-19 04:20:29.236 PMtraceinovelli blue calculateSize(8)
dev:16372025-12-19 04:20:29.235 PMtraceinovelli blue setParameter(4, 20, 8)
dev:16372025-12-19 04:20:29.230 PMtraceinovelli blue getParameter(3,333)
dev:16372025-12-19 04:20:29.226 PMtraceinovelli blue Set Private Cluster attribute 3 dataType 0x20 value 20
dev:16372025-12-19 04:20:29.225 PMtraceinovelli blue setAttribute(64561, 3, 32, 20, [:], 333)
dev:16372025-12-19 04:20:29.224 PMtraceinovelli blue calculateSize(8)
dev:16372025-12-19 04:20:29.222 PMtraceinovelli blue setParameter(3, 20, 8)
dev:16372025-12-19 04:20:29.217 PMtraceinovelli blue getParameter(2,333)
dev:16372025-12-19 04:20:29.213 PMtraceinovelli blue Set Private Cluster attribute 2 dataType 0x20 value 20
dev:16372025-12-19 04:20:29.211 PMtraceinovelli blue setAttribute(64561, 2, 32, 20, [:], 333)
dev:16372025-12-19 04:20:29.211 PMtraceinovelli blue calculateSize(8)
dev:16372025-12-19 04:20:29.209 PMtraceinovelli blue setParameter(2, 20, 8)
dev:16372025-12-19 04:20:29.200 PMtraceinovelli blue getParameter(1,333)
dev:16372025-12-19 04:20:29.190 PMtraceinovelli blue Set Private Cluster attribute 1 dataType 0x20 value 20
dev:16372025-12-19 04:20:29.185 PMtraceinovelli blue setAttribute(64561, 1, 32, 20, [:], 333)
dev:16372025-12-19 04:20:29.182 PMtraceinovelli blue calculateSize(8)
dev:16372025-12-19 04:20:29.177 PMtraceinovelli blue setParameter(1, 20, 8)
dev:16372025-12-19 04:20:29.130 PMinfoinovelli blue updated()
dev:16372025-12-19 04:09:04.975 PMinfoinovelli blue updateFirmware(switch’s fwDate: null, switch’s fwVersion: null)
dev:16372025-12-19 04:08:45.450 PMtraceinovelli blue ON_OFF_CLUSTER (cluster:0006 data:[00, 00])
dev:16372025-12-19 04:08:45.448 PMtraceinovelli blue parse(catchall: 0104 0006 01 01 0040 00 89EE 00 00 0000 0B 01 0000)
dev:16372025-12-19 04:08:45.444 PMtraceinovelli blue ON_OFF_CLUSTER (cluster:0006 data:[00, 00])
dev:16372025-12-19 04:08:45.440 PMtraceinovelli blue parse(catchall: 0104 0006 01 01 0040 00 89EE 00 00 0000 0B 01 0000)
dev:16372025-12-19 04:08:45.334 PMinfoinovelli blue off()
dev:16372025-12-19 04:03:35.408 PMinfoinovelli blue Power=0.0W
dev:16372025-12-19 04:03:35.404 PMtraceinovelli blue ELECTRICAL_MEASUREMENT_CLUSTER (cluster:0B04 attr:050B value:0000)
dev:16372025-12-19 04:03:35.388 PMtraceinovelli blue parse(read attr - raw: 89EE010B040C0B05290000, dni: 89EE, endpoint: 01, cluster: 0B04, size: 0C, attrId: 050B, encoding: 29, command: 01, value: 0000)
dev:16372025-12-19 04:03:34.444 PMinfoinovelli blue RSSI=70%
dev:16372025-12-19 04:03:34.438 PMtraceinovelli blue DIAGNOSTICS_CLUSTER (cluster:0B05 attr:011D value:B2)
dev:16372025-12-19 04:03:34.429 PMtraceinovelli blue parse(read attr - raw: 89EE010B050A1D0128B2, dni: 89EE, endpoint: 01, cluster: 0B05, size: 0A, attrId: 011D, encoding: 28, command: 01, value: B2)
dev:16372025-12-19 04:03:34.127 PMinfoinovelli blue LQI=35%
dev:16372025-12-19 04:03:34.120 PMtraceinovelli blue DIAGNOSTICS_CLUSTER (cluster:0B05 attr:011C value:58)
dev:16372025-12-19 04:03:34.114 PMtraceinovelli blue parse(read attr - raw: 89EE010B050A1C012058, dni: 89EE, endpoint: 01, cluster: 0B05, size: 0A, attrId: 011C, encoding: 20, command: 01, value: 58)
dev:16372025-12-19 04:03:34.053 PMinfoinovelli blue Energy=0.0kWh
dev:16372025-12-19 04:03:34.047 PMinfoinovelli blue ZCL Version=08
dev:16372025-12-19 04:03:34.027 PMtraceinovelli blue METERING_CLUSTER (cluster:0702 attr:0000 value:000000000000)
dev:16372025-12-19 04:03:34.015 PMtraceinovelli blue parse(read attr - raw: 89EE01070214000025000000000000, dni: 89EE, endpoint: 01, cluster: 0702, size: 14, attrId: 0000, encoding: 25, command: 01, value: 000000000000)
dev:16372025-12-19 04:03:34.013 PMtraceinovelli blue BASIC_CLUSTER (cluster:0000 attr:0000 value:08)
dev:16372025-12-19 04:03:33.895 PMtraceinovelli blue parse(read attr - raw: 89EE0100000A00002008, dni: 89EE, endpoint: 01, cluster: 0000, size: 0A, attrId: 0000, encoding: 20, command: 01, value: 08)
dev:16372025-12-19 04:03:33.818 PMinfoinovelli blue Level=209 (82%)
dev:16372025-12-19 04:03:33.804 PMtraceinovelli blue LEVEL_CONTROL_CLUSTER (cluster:0008 attr:0000 value:D1)
dev:16372025-12-19 04:03:33.797 PMtraceinovelli blue parse(read attr - raw: 89EE0100080A000020D1, dni: 89EE, endpoint: 01, cluster: 0008, size: 0A, attrId: 0000, encoding: 20, command: 01, value: D1)
dev:16372025-12-19 04:03:33.743 PMinfoinovelli blue ZCL Version=08
dev:16372025-12-19 04:03:33.734 PMtraceinovelli blue BASIC_CLUSTER (cluster:0000 attr:0000 value:08)
dev:16372025-12-19 04:03:33.717 PMtraceinovelli blue parse(read attr - raw: 89EE0100000A00002008, dni: 89EE, endpoint: 01, cluster: 0000, size: 0A, attrId: 0000, encoding: 20, command: 01, value: 08)
dev:16372025-12-19 04:03:33.296 PMinfoinovelli blue Power-On State=255 (Previous)
dev:16372025-12-19 04:03:33.293 PMtraceinovelli blue ON_OFF_CLUSTER (cluster:0006 attr:4003 value:FF)
dev:16372025-12-19 04:03:33.277 PMtraceinovelli blue parse(read attr - raw: 89EE0100060A034030FF, dni: 89EE, endpoint: 01, cluster: 0006, size: 0A, attrId: 4003, encoding: 30, command: 01, value: FF)
dev:16372025-12-19 04:03:30.568 PMtraceinovelli blue getParameter(258,333)
dev:16372025-12-19 04:03:30.559 PMtraceinovelli blue getParameter(257,333)
dev:16372025-12-19 04:03:30.537 PMtraceinovelli blue getParameter(52,333)
dev:16372025-12-19 04:03:30.524 PMtraceinovelli blue getParameter(51,333)
dev:16372025-12-19 04:03:30.512 PMtraceinovelli blue getParameter(33,333)
dev:16372025-12-19 04:03:30.503 PMtraceinovelli blue getParameter(32,333)
dev:16372025-12-19 04:03:30.438 PMtraceinovelli blue getParameter(22,333)
dev:16372025-12-19 04:03:30.414 PMtraceinovelli blue getParameter(21,333)
dev:16372025-12-19 04:03:30.304 PMtraceinovelli blue getParameter(115,333)
dev:16372025-12-19 04:03:29.946 PMtraceinovelli blue readDeviceAttributes()
dev:16372025-12-19 04:03:29.945 PMinfoinovelli blue Driver Date 2025-12-12
dev:16372025-12-19 04:03:29.942 PMinfoinovelli blue refresh()
dev:16372025-12-19 04:03:29.927 PMinfoinovelli blue ledEffectAll(255,0,0,0)
dev:16372025-12-19 04:03:29.757 PMinfoinovelli blue ledEffectOne(1234567,255,0,0,0)
dev:16372025-12-19 04:03:29.617 PMinfoinovelli blue initialize()
dev:16372025-12-19 04:03:28.035 PMtraceinovelli blue Routing Table Cluster (cluster:8032 data:[00, 00, 10, 01, 0F, B2, 07, 38, B2, 07, 9E, 28, 38, 9E, 28, 84, 49, 38, 84, 49, C0, 5C, 38, C0, 5C, 5B, 4A, 38, 5B, 4A, B6, 86, 38, B6, 86, D1, 69, 38, D1, 69, 00, 00, 03, 00, 00, 00, 00, 03, 00, 00, 4D, 1C, 00, 2A, A0, 00, 00, 03, 00, 00, 00, 00, 03, 00, 00, 00, 00, 03, 00, 00, 00, 00, 03, 00, 00, 00, 00, 03, 00, 00])
dev:16372025-12-19 04:03:27.942 PMtraceinovelli blue parse(catchall: 0000 8032 00 00 0040 00 89EE 00 00 0000 00 00 000010010FB20738B2079E28389E288449388449C05C38C05C5B4A385B4AB68638B686D16938D169000003000000000300004D1C002AA000000300000000030000000003000000000300000000030000)
dev:16372025-12-19 03:56:55.613 PMtraceinovelli blue Private Cluster (cluster:FC31 data:[10, 00])
dev:16372025-12-19 03:56:55.612 PMtraceinovelli blue parse(catchall: 0104 FC31 01 01 0040 00 89EE 00 01 122F 0B 01 1000)
dev:16372025-12-19 03:56:55.600 PMtraceinovelli blue Private Cluster (cluster:FC31 data:[10, 00])
dev:16372025-12-19 03:56:55.598 PMtraceinovelli blue parse(catchall: 0104 FC31 01 01 0040 00 89EE 00 01 122F 0B 01 1000)
dev:16372025-12-19 03:56:55.493 PMinfoinovelli blue remoteControl(Enabled)
dev:16372025-12-19 03:52:44.743 PMtraceinovelli blue ON_OFF_CLUSTER (cluster:0006 data:[00, 00])
dev:16372025-12-19 03:52:44.741 PMtraceinovelli blue parse(catchall: 0104 0006 01 01 0040 00 89EE 00 00 0000 0B 01 0000)
dev:16372025-12-19 03:52:44.708 PMtraceinovelli blue ON_OFF_CLUSTER (cluster:0006 data:[00, 00])
dev:16372025-12-19 03:52:44.707 PMtraceinovelli blue parse(catchall: 0104 0006 01 01 0040 00 89EE 00 00 0000 0B 01 0000)
dev:16372025-12-19 03:52:44.605 PMinfoinovelli blue off()
dev:16372025-12-19 03:51:48.523 PMtraceinovelli blue ON_OFF_CLUSTER (cluster:0006 data:[01, 00])
dev:16372025-12-19 03:51:48.522 PMtraceinovelli blue parse(catchall: 0104 0006 01 01 0040 00 89EE 00 00 0000 0B 01 0100)
dev:16372025-12-19 03:51:48.507 PMtraceinovelli blue ON_OFF_CLUSTER (cluster:0006 data:[01, 00])
dev:16372025-12-19 03:51:48.505 PMtraceinovelli blue parse(catchall: 0104 0006 01 01 0040 00 89EE 00 00 0000 0B 01 0100)
dev:16372025-12-19 03:51:48.443 PMinfoinovelli blue on()
dev:16372025-12-19 03:51:44.138 PMtraceinovelli blue ON_OFF_CLUSTER (cluster:0006 data:[00, 00])
dev:16372025-12-19 03:51:44.136 PMtraceinovelli blue parse(catchall: 0104 0006 01 01 0040 00 89EE 00 00 0000 0B 01 0000)
dev:16372025-12-19 03:51:44.133 PMtraceinovelli blue ON_OFF_CLUSTER (cluster:0006 data:[00, 00])
dev:16372025-12-19 03:51:44.132 PMtraceinovelli blue parse(catchall: 0104 0006 01 01 0040 00 89EE 00 00 0000 0B 01 0000)
dev:16372025-12-19 03:51:44.019 PMinfoinovelli blue off()
dev:16372025-12-19 03:49:24.647 PMtraceinovelli blue ON_OFF_CLUSTER (cluster:0006 data:[01, 00])
dev:16372025-12-19 03:49:24.646 PMtraceinovelli blue parse(catchall: 0104 0006 01 01 0040 00 89EE 00 00 0000 0B 01 0100)
dev:16372025-12-19 03:49:24.630 PMtraceinovelli blue ON_OFF_CLUSTER (cluster:0006 data:[01, 00])
dev:16372025-12-19 03:49:24.629 PMtraceinovelli blue parse(catchall: 0104 0006 01 01 0040 00 89EE 00 00 0000 0B 01 0100)
dev:16372025-12-19 03:49:24.566 PMinfoinovelli blue on()
dev:16372025-12-19 03:49:20.860 PMtraceinovelli blue ON_OFF_CLUSTER (cluster:0006 data:[00, 00])
dev:16372025-12-19 03:49:20.858 PMtraceinovelli blue parse(catchall: 0104 0006 01 01 0040 00 89EE 00 00 0000 0B 01 0000)
dev:16372025-12-19 03:49:20.854 PMtraceinovelli blue ON_OFF_CLUSTER (cluster:0006 data:[00, 00])
dev:16372025-12-19 03:49:20.852 PMtraceinovelli blue parse(catchall: 0104 0006 01 01 0040 00 89EE 00 00 0000 0B 01 0000)
dev:16372025-12-19 03:49:20.758 PMinfoinovelli blue off()
dev:16372025-12-19 03:48:52.223 PMtraceinovelli blue TEMPERATURE_CONFIGURATION_CLUSTER (cluster:0002 data:[81, 00, 00])
dev:16372025-12-19 03:48:52.222 PMtraceinovelli blue parse(catchall: 0000 0002 00 00 0040 00 89EE 00 00 0000 00 00 810000)
dev:16372025-12-19 03:48:45.596 PMinfoinovelli blue MATCH DESCRIPTOR REQUEST Device:FFFD Profile:0104 Cluster:0019
dev:16372025-12-19 03:48:45.595 PMtraceinovelli blue ON_OFF_CLUSTER (cluster:0006 data:[04, FD, FF, 04, 01, 01, 19, 00, 00])
dev:16372025-12-19 03:48:45.593 PMtraceinovelli blue parse(catchall: 0000 0006 00 00 0040 00 89EE 00 00 0000 00 00 04FDFF040101190000)
dev:16372025-12-19 03:48:42.021 PMinfoinovelli blue MATCH DESCRIPTOR REQUEST Device:0000 Profile:0104 Cluster:5701
dev:16372025-12-19 03:48:42.020 PMtraceinovelli blue ON_OFF_CLUSTER (cluster:0006 data:[03, 00, 00, 04, 01, 00, 01, 57, FC])
dev:16372025-12-19 03:48:42.018 PMtraceinovelli blue parse(catchall: 0000 0006 00 00 0040 00 89EE 00 00 0000 00 00 0300000401000157FC)
dev:16372025-12-19 03:48:40.005 PMinfoinovelli blue MATCH DESCRIPTOR REQUEST Device:0000 Profile:0104 Cluster:5701
dev:16372025-12-19 03:48:40.004 PMtraceinovelli blue ON_OFF_CLUSTER (cluster:0006 data:[02, 00, 00, 04, 01, 00, 01, 57, FC])
dev:16372025-12-19 03:48:40.002 PMtraceinovelli blue parse(catchall: 0000 0006 00 00 0040 00 89EE 00 00 0000 00 00 0200000401000157FC)
dev:16372025-12-19 03:48:38.202 PMinfoinovelli blue MATCH DESCRIPTOR REQUEST Device:0000 Profile:0104 Cluster:5701
dev:16372025-12-19 03:48:38.200 PMtraceinovelli blue ON_OFF_CLUSTER (cluster:0006 data:[01, 00, 00, 04, 01, 00, 01, 57, FC])
dev:16372025-12-19 03:48:38.193 PMtraceinovelli blue parse(catchall: 0000 0006 00 00 0040 00 89EE 00 00 0000 00 00 0100000401000157FC)
dev:16372025-12-19 03:47:43.082 PMtraceinovelli blue TEMPERATURE_CONFIGURATION_CLUSTER (cluster:0002 data:[84, 00, 00])
dev:16372025-12-19 03:47:43.080 PMtraceinovelli blue parse(catchall: 0000 0002 00 00 0040 00 89EE 00 00 0000 00 00 840000)
dev:16372025-12-19 03:47:40.502 PMtraceinovelli blue MULTISTATE_OUTPUT_CLUSTER (cluster:0013 data:[83, EE, 89, DA, 77, F7, FE, FF, 6F, 2A, 0C, 8E])
dev:16372025-12-19 03:47:40.501 PMtraceinovelli blue parse(catchall: 0000 0013 00 00 0040 00 89EE 00 00 0000 00 00 83EE89DA77F7FEFF6F2A0C8E)
dev:16372025-12-19 03:47:21.027 PMtraceinovelli blue Binding Cluster (cluster:8021 data:[B6, 00])
dev:16372025-12-19 03:47:21.026 PMtraceinovelli blue parse(catchall: 0000 8021 00 00 0040 00 89EE 00 00 0000 00 00 B600)
dev:16372025-12-19 03:47:20.731 PMtraceinovelli blue Binding Cluster (cluster:8021 data:[B5, 00])
dev:16372025-12-19 03:47:20.729 PMtraceinovelli blue parse(catchall: 0000 8021 00 00 0040 00 89EE 00 00 0000 00 00 B500)
dev:16372025-12-19 03:47:20.399 PMtraceinovelli blue Binding Cluster (cluster:8021 data:[B4, 00])
dev:16372025-12-19 03:47:20.397 PMtraceinovelli blue parse(catchall: 0000 8021 00 00 0040 00 89EE 00 00 0000 00 00 B400)
dev:16372025-12-19 03:47:20.220 PMinfoinovelli blue MATCH DESCRIPTOR REQUEST Device:0000 Profile:0104 Cluster:5701
dev:16372025-12-19 03:47:20.219 PMtraceinovelli blue ON_OFF_CLUSTER (cluster:0006 data:[03, 00, 00, 04, 01, 00, 01, 57, FC])
dev:16372025-12-19 03:47:20.217 PMtraceinovelli blue parse(catchall: 0000 0006 00 00 0040 00 89EE 00 00 0000 00 00 0300000401000157FC)
dev:16372025-12-19 03:47:20.056 PMtraceinovelli blue Binding Cluster (cluster:8021 data:[B3, 00])
dev:16372025-12-19 03:47:20.055 PMtraceinovelli blue parse(catchall: 0000 8021 00 00 0040 00 89EE 00 00 0000 00 00 B300)
dev:16372025-12-19 03:47:17.378 PMtraceinovelli blue ILLUMINANCE_MEASUREMENT_CLUSTER (cluster:0400 data:[00])
dev:16372025-12-19 03:47:17.377 PMtraceinovelli blue parse(catchall: 0104 0400 01 01 0040 00 89EE 00 00 0000 07 01 00)
dev:16372025-12-19 03:47:15.416 PMinfoinovelli blue MATCH DESCRIPTOR REQUEST Device:0000 Profile:0104 Cluster:5701
dev:16372025-12-19 03:47:15.415 PMtraceinovelli blue ON_OFF_CLUSTER (cluster:0006 data:[02, 00, 00, 04, 01, 00, 01, 57, FC])
dev:16372025-12-19 03:47:15.413 PMtraceinovelli blue parse(catchall: 0000 0006 00 00 0040 00 89EE 00 00 0000 00 00 0200000401000157FC)
dev:16372025-12-19 03:47:14.715 PMtraceinovelli blue Binding Cluster (cluster:8021 data:[B1, 00])
dev:16372025-12-19 03:47:14.708 PMtraceinovelli blue parse(catchall: 0000 8021 00 00 0040 00 89EE 00 00 0000 00 00 B100)
dev:16372025-12-19 03:47:14.378 PMtraceinovelli blue Binding Cluster (cluster:8021 data:[B0, 00])
dev:16372025-12-19 03:47:14.377 PMtraceinovelli blue parse(catchall: 0000 8021 00 00 0040 00 89EE 00 00 0000 00 00 B000)
dev:16372025-12-19 03:47:14.035 PMtraceinovelli blue Binding Cluster (cluster:8021 data:[AF, 00])
dev:16372025-12-19 03:47:14.033 PMtraceinovelli blue parse(catchall: 0000 8021 00 00 0040 00 89EE 00 00 0000 00 00 AF00)
dev:16372025-12-19 03:47:13.711 PMtraceinovelli blue Binding Cluster (cluster:8021 data:[AE, 00])
dev:16372025-12-19 03:47:13.709 PMtraceinovelli blue parse(catchall: 0000 8021 00 00 0040 00 89EE 00 00 0000 00 00 AE00)
dev:16372025-12-19 03:47:13.368 PMtraceinovelli blue Binding Cluster (cluster:8021 data:[AD, 00])
dev:16372025-12-19 03:47:13.367 PMtraceinovelli blue parse(catchall: 0000 8021 00 00 0040 00 89EE 00 00 0000 00 00 AD00)
dev:16372025-12-19 03:47:13.036 PMtraceinovelli blue Binding Cluster (cluster:8021 data:[AC, 00])
dev:16372025-12-19 03:47:13.035 PMtraceinovelli blue parse(catchall: 0000 8021 00 00 0040 00 89EE 00 00 0000 00 00 AC00)
dev:16372025-12-19 03:47:11.468 PMtraceinovelli blue TEMPERATURE_CONFIGURATION_CLUSTER (cluster:0002 data:[82, 00, 00])
dev:16372025-12-19 03:47:11.467 PMtraceinovelli blue parse(catchall: 0000 0002 00 00 0040 00 89EE 00 00 0000 00 00 820000)
dev:16372025-12-19 03:47:10.712 PMinfoinovelli blue MATCH DESCRIPTOR REQUEST Device:0000 Profile:0104 Cluster:5701
dev:16372025-12-19 03:47:10.710 PMtraceinovelli blue ON_OFF_CLUSTER (cluster:0006 data:[01, 00, 00, 04, 01, 00, 01, 57, FC])
dev:16372025-12-19 03:47:10.709 PMtraceinovelli blue parse(catchall: 0000 0006 00 00 0040 00 89EE 00 00 0000 00 00 0100000401000157FC)
dev:16372025-12-19 03:47:10.429 PMinfoinovelli blue RSSI=66%
dev:16372025-12-19 03:47:10.427 PMtraceinovelli blue DIAGNOSTICS_CLUSTER (cluster:0B05 attr:011D value:A8)
dev:16372025-12-19 03:47:10.425 PMtraceinovelli blue parse(read attr - raw: 89EE010B050A1D0128A8, dni: 89EE, endpoint: 01, cluster: 0B05, size: 0A, attrId: 011D, encoding: 28, command: 01, value: A8)
dev:16372025-12-19 03:47:10.368 PMwarninovelli blue ON_OFF_CLUSTER Unknown Attribute:null
dev:16372025-12-19 03:47:10.364 PMtraceinovelli blue ON_OFF_CLUSTER (cluster:0006 data:[00])
dev:16372025-12-19 03:47:10.363 PMtraceinovelli blue parse(catchall: 0104 0006 01 01 0040 00 89EE 00 00 0000 07 01 00)
dev:16372025-12-19 03:47:10.038 PMinfoinovelli blue LQI=19%
dev:16372025-12-19 03:47:10.034 PMtraceinovelli blue DIAGNOSTICS_CLUSTER (cluster:0B05 attr:011C value:30)
dev:16372025-12-19 03:47:10.032 PMtraceinovelli blue parse(read attr - raw: 89EE010B050A1C012030, dni: 89EE, endpoint: 01, cluster: 0B05, size: 0A, attrId: 011C, encoding: 20, command: 01, value: 30)
dev:16372025-12-19 03:47:09.702 PMinfoinovelli blue Power=0.0W
dev:16372025-12-19 03:47:09.701 PMtraceinovelli blue ELECTRICAL_MEASUREMENT_CLUSTER (cluster:0B04 attr:050B value:0000)
dev:16372025-12-19 03:47:09.698 PMtraceinovelli blue parse(read attr - raw: 89EE010B040C0B05290000, dni: 89EE, endpoint: 01, cluster: 0B04, size: 0C, attrId: 050B, encoding: 29, command: 01, value: 0000)
dev:16372025-12-19 03:47:09.434 PMtraceinovelli blue MULTISTATE_OUTPUT_CLUSTER (cluster:0013 data:[81, EE, 89, DA, 77, F7, FE, FF, 6F, 2A, 0C, 8E])
dev:16372025-12-19 03:47:09.432 PMtraceinovelli blue parse(catchall: 0000 0013 00 00 0040 00 89EE 00 00 0000 00 00 81EE89DA77F7FEFF6F2A0C8E)
dev:16372025-12-19 03:47:07.996 PMtraceinovelli blue Binding Cluster (cluster:8021 data:[A1, 00])
dev:16372025-12-19 03:47:07.995 PMtraceinovelli blue parse(catchall: 0000 8021 00 00 0040 00 89EE 00 00 0000 00 00 A100)
dev:16372025-12-19 03:47:07.564 PMtraceinovelli blue Binding Cluster (cluster:8021 data:[96, 00])
dev:16372025-12-19 03:47:07.557 PMtraceinovelli blue parse(catchall: 0000 8021 00 00 0040 00 89EE 00 00 0000 00 00 9600)
dev:16372025-12-19 03:47:07.306 PMtraceinovelli blue getParameter(258,333)
dev:16372025-12-19 03:47:07.304 PMtraceinovelli blue getParameter(257,333)
dev:16372025-12-19 03:47:07.298 PMtraceinovelli blue getParameter(52,333)
dev:16372025-12-19 03:47:07.294 PMtraceinovelli blue getParameter(51,333)
dev:16372025-12-19 03:47:07.291 PMtraceinovelli blue getParameter(33,333)
dev:16372025-12-19 03:47:07.288 PMtraceinovelli blue getParameter(32,333)
dev:16372025-12-19 03:47:07.285 PMtraceinovelli blue getParameter(22,333)
dev:16372025-12-19 03:47:07.282 PMtraceinovelli blue getParameter(21,333)
dev:16372025-12-19 03:47:07.271 PMtraceinovelli blue getParameter(115,333)
dev:16372025-12-19 03:47:07.254 PMtraceinovelli blue readDeviceAttributes()
dev:16372025-12-19 03:47:07.253 PMinfoinovelli blue Driver Date 2025-12-12
dev:16372025-12-19 03:47:07.250 PMinfoinovelli blue refresh()
dev:16372025-12-19 03:47:07.238 PMinfoinovelli blue re-establish lifeline bindings to hub
Being that the Zigbee pairing info is stored you may want to try removing the switch from the hub and and clear any of the device information by doing a factory reset and then pair it as a new device (do not use the existing zigbee switch and let it pair as a new device. The pairing process for some reason on the C8 Pro and zigbee devices is as soon as the LED bar starts with the green flash it needs to be pulled and then wait for the 10’ish seconds and then push it back in. If you wait until after the green to pull the air gap it does not seem to work. Also make sure you are using the most current driver. I have the C5, C7, C8, and C8 Pro and the C8 Pro is the only hub that this issue happens on but if not followed there seems to be issues with the switch and how it reports and functions. I think the hub causes the pairing process to loop and corrupt the data. I have seen this with multiple Zigbee devices and the C8 Pro.
Ok Thanks. I will remove the device from my C8-Pro. Do the factory reset on the switch. Start the pairing process and as soon as I see the green on the led bar on the switch I will put the airgap wait for 10 seconds and then push it back in.
You have to be really fast when that green comes up. Got it to pair properly this time. Seeing the off and on events in the logs, power, button presses etc. If I run into any other questions I will post in another thread but now one switch running for testing config in my office and then on to the real test with the other switches in the house and the wife acceptance
