Hubitat notification LED
I have added the lzw31 (red dimmer gen 2) successfully in hubitat. I installed the driver and I see all the options for the switch. I would like the LED on the switch to reflect the state of the light. Normally this happens automatically based on the load, however I have disabled the local relay since I have hue smart bulbs and I wanted them always powered on. I have setup a rule to turn on and turn off the hue bulb based on up/down button presses but the LED just stays on (I realize this is what should happen). Looking for the LED to turn on when light is on, and off when light is off. I see options for creating child devices which can then be used in the smart apps section?
Have you installed the child device driver? You can find it with everything else on GitHub.
This?
