Hubitat: Red Series (VZW31-SN) 3-Way dumb switch config - lights flashing
Hello:
I just replaced 2 Gen 2 Red series dimmers (LZW31-SN) with the current Red series dimmers (VZW31-SN). Both devices are in 3 way (dumb switch) configuration and have paired correctly with Hubitat and the lights work correctly from Hubitat and from the physical Inovelli switch.
However, in one case, if the light is turned on from the “dumb” switch, the lights keep flashing (on/off). If the light is turned on from the Inovelli switch, this does not happen.
The second switch works correctly (either from the Inovelli physical switch or from the dumb switch).
The setup for the switches is the same. The one that works correctly controls 6 overhead canned lights with LED bulbs. The one that does not work correctly controls 4 LED bulbs in an overhead light fixture.
Any idea on what could be causing this? Firmware on both switches is 1.03. Thanks for your help.
Changing Parameter 10 (max level) to 80% fixed the issue.
