Humming when dimming on Blue switches with LED Wafer lights
Hooked up my lights and everything works great. The only problem is the switches buzz when I dim them. It’s perfectly silent when at full on/off but when dimmed it buzzes. Any suggestions on things to try?
3 blue switches in one box, connected to GE Add on Switches. The switches control 12 LED wafer lights each.
These are the lights: Amico 20 Pack 6 Inch 5CCT Ultra-Thin LED Recessed Ceiling Light with Junction Box, 2700K/3000K/3500K/4000K/5000K Selectable, 12W Eqv 110W, Dimmable Can-Killer Downlight, 1050LM Wafer Lighting - ETL - Amazon.com
Did you ever figure out your humming issue? I was considering those same lights and was concerned about buzzing.
I’m not sure if you had this problem before or after the firmware change to modify switch from leading to trailing edge dimming and if that solved the problem with the switches.
I would appreciate any feedback on how the lights have worked for you and if you received the switch humming.
I had this same issue but it varied between different red/blue dimmers. I had about 10 dimmers to choose from and by swapping them out I finally found a red series dimmer that exhibited a low/acceptable amount of audible hum. I also RMA’d the worst offender of the group for a new unit.
