Hello,
I set up a test in Node Red via Home Assistant to investigate this, but I can’t sort out what’s going on here.
Depending on the value I choose, brightness values are skipped, and do not set properly.
I considered that this might be due to setting minimum and maximum brightness in the zwave settings, but I am not sure.
I set up a little test for your viewing pleasure. For every value 1-255, I set the brightness, then checked it. See the CSV results here.
Any thoughts on this behavior?
