Incorrect ramp timing by a factor of ×10 (blue series dimmer)
Greetings,
I have several blue series dimmers in my home. Home Assistant and Z2M is used in all cases. Firmware v2.18. One out of all of the dimmers is experiencing a strange issue. The timing is off by a factor of 10 only in the downward direction. For example, setting of 120 for the RampRateOnToOffRemote parameter produces a 1.2 second fade down instead of the expected 12 second fade time. A setting of 90 produces a 0.9 second fade. A setting of 50 produces a 0.5 second fade, etc. Only setting the DimmingSpeedUpRemote to some value and then setting the others to match (setting them to 127) do I see what is expected behavior. So it appears that the dimmer can produce the expected outcome but somewhere in the mix numbers are being multiplied?
The only difference between this dimmer and all of the others is that it is being used in a multi-way setting with an Inovelli Aux switch. Z2M settings are correctly matched to this scenario. The switch also correctly reports neutral power.
I have tried all of the usual suspects: air gap, factory default reset, reboot HA, re-configure, changing settings in Z2M, etc
Any ideas what is going on here and how to fix this?
Thanks,
Richard
Perhaps I have a trend going with the ×10 error factor… see my other thread: Incorrect power reporting by a factor of ×10 (blue series dimmer) In truth I believe these are unrelated of course but the coincidence is not lost on me :wink:
Hi @rpulivella, can you record the z2m logs while you change the setting? Let’s make sure the right command is being sent to the switch.
Also, are you binding to Zigbee bulbs or just have a dimmable load attached?
Yes though I’ve not done that before. Is this a copy paste of what I can see on the log tab of Z2M or something else? What log level should I use when I capture this?
It is a dimmable load (light bulbs) in this case. I also should add that I get the same outcome whether I am tapping buttons on the switch or remote controlling. Meaning toggling the light off in HA’s UI produces the same incorrect timing as toggling the light off at the switch.
I believe the default log level should be enough. I usually tail my containers log while I send the command with this:
docker logs -f --tail 100 zigbee2mqtt
Yours might be a little different based on the environment.
Good to see it isn’t bound to a bulb or a group because sometimes smart bulbs have their own rates and they don’t always play nice with what our switch has set.
I’m going to try to change this config in my own install to see if I can replicate.
Z2M in my HA setup is running as an Add-On. Not sure if I can issue commands to docker directly but I’ll investigate further this weekend. Here is what I see in the Z2M UI logs when I tap the switch once to go to maximum and then again to turn it off. I should be seeing a very slow fade down looking at the settings.
Info 2025-02-14 08:50:57z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/floor1/diningRoom/chandelier', payload '{"activeEnergyReports":10,"activePowerReports":10,"autoTimerOff":0,"auxSwitchUniqueScenes":"Disabled","bindingOffToOnSyncLevel":"Enabled","brightness":19,"brightnessLevelForDoubleTapDown":2,"brightnessLevelForDoubleTapUp":254,"buttonDelay":"0ms","defaultLed1ColorWhenOff":255,"defaultLed1ColorWhenOn":255,"defaultLed1IntensityWhenOff":0,"defaultLed1IntensityWhenOn":101,"defaultLed2ColorWhenOff":255,"defaultLed2ColorWhenOn":255,"defaultLed2IntensityWhenOff":0,"defaultLed2IntensityWhenOn":101,"defaultLed3ColorWhenOff":255,"defaultLed3ColorWhenOn":255,"defaultLed3IntensityWhenOff":0,"defaultLed3IntensityWhenOn":101,"defaultLed4ColorWhenOff":255,"defaultLed4ColorWhenOn":255,"defaultLed4IntensityWhenOff":0,"defaultLed4IntensityWhenOn":101,"defaultLed5ColorWhenOff":255,"defaultLed5ColorWhenOn":255,"defaultLed5IntensityWhenOff":0,"defaultLed5IntensityWhenOn":101,"defaultLed6ColorWhenOff":255,"defaultLed6ColorWhenOn":255,"defaultLed6IntensityWhenOff":0,"defaultLed6IntensityWhenOn":101,"defaultLed7ColorWhenOff":255,"defaultLed7ColorWhenOn":255,"defaultLed7IntensityWhenOff":101,"defaultLed7IntensityWhenOn":101,"defaultLevelLocal":254,"defaultLevelRemote":19,"deviceBindNumber":0,"dimmingMode":"Leading edge","dimmingSpeedDownLocal":126,"dimmingSpeedDownRemote":126,"dimmingSpeedUpLocal":127,"dimmingSpeedUpRemote":8,"doubleTapClearNotifications":"Enabled (Default)","doubleTapDownToParam56":"Disabled","doubleTapUpToParam55":"Disabled","energy":2.22,"fanControlMode":"Disabled","fanLedLevelType":0,"firmwareUpdateInProgressIndicator":"Enabled","highLevelForFanControlMode":254,"higherOutputInNonNeutral":"Disabled (default)","identify":null,"individual_led_effect":null,"internalTemperature":27,"invertSwitch":"No","last_seen":"2025-02-14T08:50:57-05:00","ledBarScaling":"Gen3 method (VZM-style)","ledColorForFanControlMode":255,"ledColorWhenOff":16,"ledColorWhenOn":16,"ledIntensityWhenOff":5,"ledIntensityWhenOn":30,"led_effect":null,"linkquality":180,"loadLevelIndicatorTimeout":"Stay On","localProtection":"Disabled","lowLevelForFanControlMode":63,"maximumLevel":240,"mediumLevelForFanControlMode":128,"minimumLevel":51,"onOffLedMode":"All","outputMode":"Dimmer","overheat":"No Alert","periodicPowerAndEnergyReports":3600,"power":2.9,"powerType":"Neutral","quickStartLevel":254,"quickStartTime":0,"rampRateOffToOnLocal":127,"rampRateOffToOnRemote":127,"rampRateOnToOffLocal":126,"rampRateOnToOffRemote":126,"relayClick":"Disabled (Click Sound On)","remoteProtection":"Disabled","singleTapBehavior":"Old Behavior","smartBulbMode":"Disabled","state":"ON","stateAfterPowerRestored":255,"switchType":"3-Way Aux Switch","update":{"installed_version":16908818,"latest_version":16908818,"state":"idle"}}'
Info 2025-02-14 08:51:00z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/floor1/diningRoom/chandelier', payload '{"action":"up_single","activeEnergyReports":10,"activePowerReports":10,"autoTimerOff":0,"auxSwitchUniqueScenes":"Disabled","bindingOffToOnSyncLevel":"Enabled","brightness":19,"brightnessLevelForDoubleTapDown":2,"brightnessLevelForDoubleTapUp":254,"buttonDelay":"0ms","defaultLed1ColorWhenOff":255,"defaultLed1ColorWhenOn":255,"defaultLed1IntensityWhenOff":0,"defaultLed1IntensityWhenOn":101,"defaultLed2ColorWhenOff":255,"defaultLed2ColorWhenOn":255,"defaultLed2IntensityWhenOff":0,"defaultLed2IntensityWhenOn":101,"defaultLed3ColorWhenOff":255,"defaultLed3ColorWhenOn":255,"defaultLed3IntensityWhenOff":0,"defaultLed3IntensityWhenOn":101,"defaultLed4ColorWhenOff":255,"defaultLed4ColorWhenOn":255,"defaultLed4IntensityWhenOff":0,"defaultLed4IntensityWhenOn":101,"defaultLed5ColorWhenOff":255,"defaultLed5ColorWhenOn":255,"defaultLed5IntensityWhenOff":0,"defaultLed5IntensityWhenOn":101,"defaultLed6ColorWhenOff":255,"defaultLed6ColorWhenOn":255,"defaultLed6IntensityWhenOff":0,"defaultLed6IntensityWhenOn":101,"defaultLed7ColorWhenOff":255,"defaultLed7ColorWhenOn":255,"defaultLed7IntensityWhenOff":101,"defaultLed7IntensityWhenOn":101,"defaultLevelLocal":254,"defaultLevelRemote":19,"deviceBindNumber":0,"dimmingMode":"Leading edge","dimmingSpeedDownLocal":126,"dimmingSpeedDownRemote":126,"dimmingSpeedUpLocal":127,"dimmingSpeedUpRemote":8,"doubleTapClearNotifications":"Enabled (Default)","doubleTapDownToParam56":"Disabled","doubleTapUpToParam55":"Disabled","energy":2.22,"fanControlMode":"Disabled","fanLedLevelType":0,"firmwareUpdateInProgressIndicator":"Enabled","highLevelForFanControlMode":254,"higherOutputInNonNeutral":"Disabled (default)","identify":null,"individual_led_effect":null,"internalTemperature":27,"invertSwitch":"No","last_seen":"2025-02-14T08:51:00-05:00","ledBarScaling":"Gen3 method (VZM-style)","ledColorForFanControlMode":255,"ledColorWhenOff":16,"ledColorWhenOn":16,"ledIntensityWhenOff":5,"ledIntensityWhenOn":30,"led_effect":null,"linkquality":175,"loadLevelIndicatorTimeout":"Stay On","localProtection":"Disabled","lowLevelForFanControlMode":63,"maximumLevel":240,"mediumLevelForFanControlMode":128,"minimumLevel":51,"onOffLedMode":"All","outputMode":"Dimmer","overheat":"No Alert","periodicPowerAndEnergyReports":3600,"power":2.9,"powerType":"Neutral","quickStartLevel":254,"quickStartTime":0,"rampRateOffToOnLocal":127,"rampRateOffToOnRemote":127,"rampRateOnToOffLocal":126,"rampRateOnToOffRemote":126,"relayClick":"Disabled (Click Sound On)","remoteProtection":"Disabled","singleTapBehavior":"Old Behavior","smartBulbMode":"Disabled","state":"ON","stateAfterPowerRestored":255,"switchType":"3-Way Aux Switch","update":{"installed_version":16908818,"latest_version":16908818,"state":"idle"}}'
Info 2025-02-14 08:51:00z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/floor1/diningRoom/chandelier/action', payload 'up_single'
Info 2025-02-14 08:51:00z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/floor1/diningRoom/chandelier', payload '{"activeEnergyReports":10,"activePowerReports":10,"autoTimerOff":0,"auxSwitchUniqueScenes":"Disabled","bindingOffToOnSyncLevel":"Enabled","brightness":21,"brightnessLevelForDoubleTapDown":2,"brightnessLevelForDoubleTapUp":254,"buttonDelay":"0ms","defaultLed1ColorWhenOff":255,"defaultLed1ColorWhenOn":255,"defaultLed1IntensityWhenOff":0,"defaultLed1IntensityWhenOn":101,"defaultLed2ColorWhenOff":255,"defaultLed2ColorWhenOn":255,"defaultLed2IntensityWhenOff":0,"defaultLed2IntensityWhenOn":101,"defaultLed3ColorWhenOff":255,"defaultLed3ColorWhenOn":255,"defaultLed3IntensityWhenOff":0,"defaultLed3IntensityWhenOn":101,"defaultLed4ColorWhenOff":255,"defaultLed4ColorWhenOn":255,"defaultLed4IntensityWhenOff":0,"defaultLed4IntensityWhenOn":101,"defaultLed5ColorWhenOff":255,"defaultLed5ColorWhenOn":255,"defaultLed5IntensityWhenOff":0,"defaultLed5IntensityWhenOn":101,"defaultLed6ColorWhenOff":255,"defaultLed6ColorWhenOn":255,"defaultLed6IntensityWhenOff":0,"defaultLed6IntensityWhenOn":101,"defaultLed7ColorWhenOff":255,"defaultLed7ColorWhenOn":255,"defaultLed7IntensityWhenOff":101,"defaultLed7IntensityWhenOn":101,"defaultLevelLocal":254,"defaultLevelRemote":19,"deviceBindNumber":0,"dimmingMode":"Leading edge","dimmingSpeedDownLocal":126,"dimmingSpeedDownRemote":126,"dimmingSpeedUpLocal":127,"dimmingSpeedUpRemote":8,"doubleTapClearNotifications":"Enabled (Default)","doubleTapDownToParam56":"Disabled","doubleTapUpToParam55":"Disabled","energy":2.22,"fanControlMode":"Disabled","fanLedLevelType":0,"firmwareUpdateInProgressIndicator":"Enabled","highLevelForFanControlMode":254,"higherOutputInNonNeutral":"Disabled (default)","identify":null,"individual_led_effect":null,"internalTemperature":27,"invertSwitch":"No","last_seen":"2025-02-14T08:51:01-05:00","ledBarScaling":"Gen3 method (VZM-style)","ledColorForFanControlMode":255,"ledColorWhenOff":16,"ledColorWhenOn":16,"ledIntensityWhenOff":5,"ledIntensityWhenOn":30,"led_effect":null,"linkquality":181,"loadLevelIndicatorTimeout":"Stay On","localProtection":"Disabled","lowLevelForFanControlMode":63,"maximumLevel":240,"mediumLevelForFanControlMode":128,"minimumLevel":51,"onOffLedMode":"All","outputMode":"Dimmer","overheat":"No Alert","periodicPowerAndEnergyReports":3600,"power":2.9,"powerType":"Neutral","quickStartLevel":254,"quickStartTime":0,"rampRateOffToOnLocal":127,"rampRateOffToOnRemote":127,"rampRateOnToOffLocal":126,"rampRateOnToOffRemote":126,"relayClick":"Disabled (Click Sound On)","remoteProtection":"Disabled","singleTapBehavior":"Old Behavior","smartBulbMode":"Disabled","state":"ON","stateAfterPowerRestored":255,"switchType":"3-Way Aux Switch","update":{"installed_version":16908818,"latest_version":16908818,"state":"idle"}}'
Info 2025-02-14 08:51:02z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/floor1/diningRoom/chandelier', payload '{"activeEnergyReports":10,"activePowerReports":10,"autoTimerOff":0,"auxSwitchUniqueScenes":"Disabled","bindingOffToOnSyncLevel":"Enabled","brightness":21,"brightnessLevelForDoubleTapDown":2,"brightnessLevelForDoubleTapUp":254,"buttonDelay":"0ms","defaultLed1ColorWhenOff":255,"defaultLed1ColorWhenOn":255,"defaultLed1IntensityWhenOff":0,"defaultLed1IntensityWhenOn":101,"defaultLed2ColorWhenOff":255,"defaultLed2ColorWhenOn":255,"defaultLed2IntensityWhenOff":0,"defaultLed2IntensityWhenOn":101,"defaultLed3ColorWhenOff":255,"defaultLed3ColorWhenOn":255,"defaultLed3IntensityWhenOff":0,"defaultLed3IntensityWhenOn":101,"defaultLed4ColorWhenOff":255,"defaultLed4ColorWhenOn":255,"defaultLed4IntensityWhenOff":0,"defaultLed4IntensityWhenOn":101,"defaultLed5ColorWhenOff":255,"defaultLed5ColorWhenOn":255,"defaultLed5IntensityWhenOff":0,"defaultLed5IntensityWhenOn":101,"defaultLed6ColorWhenOff":255,"defaultLed6ColorWhenOn":255,"defaultLed6IntensityWhenOff":0,"defaultLed6IntensityWhenOn":101,"defaultLed7ColorWhenOff":255,"defaultLed7ColorWhenOn":255,"defaultLed7IntensityWhenOff":101,"defaultLed7IntensityWhenOn":101,"defaultLevelLocal":254,"defaultLevelRemote":19,"deviceBindNumber":0,"dimmingMode":"Leading edge","dimmingSpeedDownLocal":126,"dimmingSpeedDownRemote":126,"dimmingSpeedUpLocal":127,"dimmingSpeedUpRemote":8,"doubleTapClearNotifications":"Enabled (Default)","doubleTapDownToParam56":"Disabled","doubleTapUpToParam55":"Disabled","energy":2.22,"fanControlMode":"Disabled","fanLedLevelType":0,"firmwareUpdateInProgressIndicator":"Enabled","highLevelForFanControlMode":254,"higherOutputInNonNeutral":"Disabled (default)","identify":null,"individual_led_effect":null,"internalTemperature":27,"invertSwitch":"No","last_seen":"2025-02-14T08:51:02-05:00","ledBarScaling":"Gen3 method (VZM-style)","ledColorForFanControlMode":255,"ledColorWhenOff":16,"ledColorWhenOn":16,"ledIntensityWhenOff":5,"ledIntensityWhenOn":30,"led_effect":null,"linkquality":178,"loadLevelIndicatorTimeout":"Stay On","localProtection":"Disabled","lowLevelForFanControlMode":63,"maximumLevel":240,"mediumLevelForFanControlMode":128,"minimumLevel":51,"onOffLedMode":"All","outputMode":"Dimmer","overheat":"No Alert","periodicPowerAndEnergyReports":3600,"power":32.2,"powerType":"Neutral","quickStartLevel":254,"quickStartTime":0,"rampRateOffToOnLocal":127,"rampRateOffToOnRemote":127,"rampRateOnToOffLocal":126,"rampRateOnToOffRemote":126,"relayClick":"Disabled (Click Sound On)","remoteProtection":"Disabled","singleTapBehavior":"Old Behavior","smartBulbMode":"Disabled","state":"ON","stateAfterPowerRestored":255,"switchType":"3-Way Aux Switch","update":{"installed_version":16908818,"latest_version":16908818,"state":"idle"}}'
Info 2025-02-14 08:51:02z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/floor1/diningRoom/chandelier', payload '{"activeEnergyReports":10,"activePowerReports":10,"autoTimerOff":0,"auxSwitchUniqueScenes":"Disabled","bindingOffToOnSyncLevel":"Enabled","brightness":254,"brightnessLevelForDoubleTapDown":2,"brightnessLevelForDoubleTapUp":254,"buttonDelay":"0ms","defaultLed1ColorWhenOff":255,"defaultLed1ColorWhenOn":255,"defaultLed1IntensityWhenOff":0,"defaultLed1IntensityWhenOn":101,"defaultLed2ColorWhenOff":255,"defaultLed2ColorWhenOn":255,"defaultLed2IntensityWhenOff":0,"defaultLed2IntensityWhenOn":101,"defaultLed3ColorWhenOff":255,"defaultLed3ColorWhenOn":255,"defaultLed3IntensityWhenOff":0,"defaultLed3IntensityWhenOn":101,"defaultLed4ColorWhenOff":255,"defaultLed4ColorWhenOn":255,"defaultLed4IntensityWhenOff":0,"defaultLed4IntensityWhenOn":101,"defaultLed5ColorWhenOff":255,"defaultLed5ColorWhenOn":255,"defaultLed5IntensityWhenOff":0,"defaultLed5IntensityWhenOn":101,"defaultLed6ColorWhenOff":255,"defaultLed6ColorWhenOn":255,"defaultLed6IntensityWhenOff":0,"defaultLed6IntensityWhenOn":101,"defaultLed7ColorWhenOff":255,"defaultLed7ColorWhenOn":255,"defaultLed7IntensityWhenOff":101,"defaultLed7IntensityWhenOn":101,"defaultLevelLocal":254,"defaultLevelRemote":19,"deviceBindNumber":0,"dimmingMode":"Leading edge","dimmingSpeedDownLocal":126,"dimmingSpeedDownRemote":126,"dimmingSpeedUpLocal":127,"dimmingSpeedUpRemote":8,"doubleTapClearNotifications":"Enabled (Default)","doubleTapDownToParam56":"Disabled","doubleTapUpToParam55":"Disabled","energy":2.22,"fanControlMode":"Disabled","fanLedLevelType":0,"firmwareUpdateInProgressIndicator":"Enabled","highLevelForFanControlMode":254,"higherOutputInNonNeutral":"Disabled (default)","identify":null,"individual_led_effect":null,"internalTemperature":27,"invertSwitch":"No","last_seen":"2025-02-14T08:51:02-05:00","ledBarScaling":"Gen3 method (VZM-style)","ledColorForFanControlMode":255,"ledColorWhenOff":16,"ledColorWhenOn":16,"ledIntensityWhenOff":5,"ledIntensityWhenOn":30,"led_effect":null,"linkquality":178,"loadLevelIndicatorTimeout":"Stay On","localProtection":"Disabled","lowLevelForFanControlMode":63,"maximumLevel":240,"mediumLevelForFanControlMode":128,"minimumLevel":51,"onOffLedMode":"All","outputMode":"Dimmer","overheat":"No Alert","periodicPowerAndEnergyReports":3600,"power":32.2,"powerType":"Neutral","quickStartLevel":254,"quickStartTime":0,"rampRateOffToOnLocal":127,"rampRateOffToOnRemote":127,"rampRateOnToOffLocal":126,"rampRateOnToOffRemote":126,"relayClick":"Disabled (Click Sound On)","remoteProtection":"Disabled","singleTapBehavior":"Old Behavior","smartBulbMode":"Disabled","state":"ON","stateAfterPowerRestored":255,"switchType":"3-Way Aux Switch","update":{"installed_version":16908818,"latest_version":16908818,"state":"idle"}}'
Info 2025-02-14 08:51:04z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/floor1/diningRoom/chandelier', payload '{"action":"down_single","activeEnergyReports":10,"activePowerReports":10,"autoTimerOff":0,"auxSwitchUniqueScenes":"Disabled","bindingOffToOnSyncLevel":"Enabled","brightness":254,"brightnessLevelForDoubleTapDown":2,"brightnessLevelForDoubleTapUp":254,"buttonDelay":"0ms","defaultLed1ColorWhenOff":255,"defaultLed1ColorWhenOn":255,"defaultLed1IntensityWhenOff":0,"defaultLed1IntensityWhenOn":101,"defaultLed2ColorWhenOff":255,"defaultLed2ColorWhenOn":255,"defaultLed2IntensityWhenOff":0,"defaultLed2IntensityWhenOn":101,"defaultLed3ColorWhenOff":255,"defaultLed3ColorWhenOn":255,"defaultLed3IntensityWhenOff":0,"defaultLed3IntensityWhenOn":101,"defaultLed4ColorWhenOff":255,"defaultLed4ColorWhenOn":255,"defaultLed4IntensityWhenOff":0,"defaultLed4IntensityWhenOn":101,"defaultLed5ColorWhenOff":255,"defaultLed5ColorWhenOn":255,"defaultLed5IntensityWhenOff":0,"defaultLed5IntensityWhenOn":101,"defaultLed6ColorWhenOff":255,"defaultLed6ColorWhenOn":255,"defaultLed6IntensityWhenOff":0,"defaultLed6IntensityWhenOn":101,"defaultLed7ColorWhenOff":255,"defaultLed7ColorWhenOn":255,"defaultLed7IntensityWhenOff":101,"defaultLed7IntensityWhenOn":101,"defaultLevelLocal":254,"defaultLevelRemote":19,"deviceBindNumber":0,"dimmingMode":"Leading edge","dimmingSpeedDownLocal":126,"dimmingSpeedDownRemote":126,"dimmingSpeedUpLocal":127,"dimmingSpeedUpRemote":8,"doubleTapClearNotifications":"Enabled (Default)","doubleTapDownToParam56":"Disabled","doubleTapUpToParam55":"Disabled","energy":2.22,"fanControlMode":"Disabled","fanLedLevelType":0,"firmwareUpdateInProgressIndicator":"Enabled","highLevelForFanControlMode":254,"higherOutputInNonNeutral":"Disabled (default)","identify":null,"individual_led_effect":null,"internalTemperature":27,"invertSwitch":"No","last_seen":"2025-02-14T08:51:04-05:00","ledBarScaling":"Gen3 method (VZM-style)","ledColorForFanControlMode":255,"ledColorWhenOff":16,"ledColorWhenOn":16,"ledIntensityWhenOff":5,"ledIntensityWhenOn":30,"led_effect":null,"linkquality":176,"loadLevelIndicatorTimeout":"Stay On","localProtection":"Disabled","lowLevelForFanControlMode":63,"maximumLevel":240,"mediumLevelForFanControlMode":128,"minimumLevel":51,"onOffLedMode":"All","outputMode":"Dimmer","overheat":"No Alert","periodicPowerAndEnergyReports":3600,"power":32.2,"powerType":"Neutral","quickStartLevel":254,"quickStartTime":0,"rampRateOffToOnLocal":127,"rampRateOffToOnRemote":127,"rampRateOnToOffLocal":126,"rampRateOnToOffRemote":126,"relayClick":"Disabled (Click Sound On)","remoteProtection":"Disabled","singleTapBehavior":"Old Behavior","smartBulbMode":"Disabled","state":"ON","stateAfterPowerRestored":255,"switchType":"3-Way Aux Switch","update":{"installed_version":16908818,"latest_version":16908818,"state":"idle"}}'
Info 2025-02-14 08:51:04z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/floor1/diningRoom/chandelier/action', payload 'down_single'
Info 2025-02-14 08:51:04z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/floor1/diningRoom/chandelier', payload '{"activeEnergyReports":10,"activePowerReports":10,"autoTimerOff":0,"auxSwitchUniqueScenes":"Disabled","bindingOffToOnSyncLevel":"Enabled","brightness":254,"brightnessLevelForDoubleTapDown":2,"brightnessLevelForDoubleTapUp":254,"buttonDelay":"0ms","defaultLed1ColorWhenOff":255,"defaultLed1ColorWhenOn":255,"defaultLed1IntensityWhenOff":0,"defaultLed1IntensityWhenOn":101,"defaultLed2ColorWhenOff":255,"defaultLed2ColorWhenOn":255,"defaultLed2IntensityWhenOff":0,"defaultLed2IntensityWhenOn":101,"defaultLed3ColorWhenOff":255,"defaultLed3ColorWhenOn":255,"defaultLed3IntensityWhenOff":0,"defaultLed3IntensityWhenOn":101,"defaultLed4ColorWhenOff":255,"defaultLed4ColorWhenOn":255,"defaultLed4IntensityWhenOff":0,"defaultLed4IntensityWhenOn":101,"defaultLed5ColorWhenOff":255,"defaultLed5ColorWhenOn":255,"defaultLed5IntensityWhenOff":0,"defaultLed5IntensityWhenOn":101,"defaultLed6ColorWhenOff":255,"defaultLed6ColorWhenOn":255,"defaultLed6IntensityWhenOff":0,"defaultLed6IntensityWhenOn":101,"defaultLed7ColorWhenOff":255,"defaultLed7ColorWhenOn":255,"defaultLed7IntensityWhenOff":101,"defaultLed7IntensityWhenOn":101,"defaultLevelLocal":254,"defaultLevelRemote":19,"deviceBindNumber":0,"dimmingMode":"Leading edge","dimmingSpeedDownLocal":126,"dimmingSpeedDownRemote":126,"dimmingSpeedUpLocal":127,"dimmingSpeedUpRemote":8,"doubleTapClearNotifications":"Enabled (Default)","doubleTapDownToParam56":"Disabled","doubleTapUpToParam55":"Disabled","energy":2.22,"fanControlMode":"Disabled","fanLedLevelType":0,"firmwareUpdateInProgressIndicator":"Enabled","highLevelForFanControlMode":254,"higherOutputInNonNeutral":"Disabled (default)","identify":null,"individual_led_effect":null,"internalTemperature":27,"invertSwitch":"No","last_seen":"2025-02-14T08:51:04-05:00","ledBarScaling":"Gen3 method (VZM-style)","ledColorForFanControlMode":255,"ledColorWhenOff":16,"ledColorWhenOn":16,"ledIntensityWhenOff":5,"ledIntensityWhenOn":30,"led_effect":null,"linkquality":178,"loadLevelIndicatorTimeout":"Stay On","localProtection":"Disabled","lowLevelForFanControlMode":63,"maximumLevel":240,"mediumLevelForFanControlMode":128,"minimumLevel":51,"onOffLedMode":"All","outputMode":"Dimmer","overheat":"No Alert","periodicPowerAndEnergyReports":3600,"power":32.2,"powerType":"Neutral","quickStartLevel":254,"quickStartTime":0,"rampRateOffToOnLocal":127,"rampRateOffToOnRemote":127,"rampRateOnToOffLocal":126,"rampRateOnToOffRemote":126,"relayClick":"Disabled (Click Sound On)","remoteProtection":"Disabled","singleTapBehavior":"Old Behavior","smartBulbMode":"Disabled","state":"OFF","stateAfterPowerRestored":255,"switchType":"3-Way Aux Switch","update":{"installed_version":16908818,"latest_version":16908818,"state":"idle"}}'
Info 2025-02-14 08:51:05z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/floor1/diningRoom/chandelier', payload '{"activeEnergyReports":10,"activePowerReports":10,"autoTimerOff":0,"auxSwitchUniqueScenes":"Disabled","bindingOffToOnSyncLevel":"Enabled","brightness":254,"brightnessLevelForDoubleTapDown":2,"brightnessLevelForDoubleTapUp":254,"buttonDelay":"0ms","defaultLed1ColorWhenOff":255,"defaultLed1ColorWhenOn":255,"defaultLed1IntensityWhenOff":0,"defaultLed1IntensityWhenOn":101,"defaultLed2ColorWhenOff":255,"defaultLed2ColorWhenOn":255,"defaultLed2IntensityWhenOff":0,"defaultLed2IntensityWhenOn":101,"defaultLed3ColorWhenOff":255,"defaultLed3ColorWhenOn":255,"defaultLed3IntensityWhenOff":0,"defaultLed3IntensityWhenOn":101,"defaultLed4ColorWhenOff":255,"defaultLed4ColorWhenOn":255,"defaultLed4IntensityWhenOff":0,"defaultLed4IntensityWhenOn":101,"defaultLed5ColorWhenOff":255,"defaultLed5ColorWhenOn":255,"defaultLed5IntensityWhenOff":0,"defaultLed5IntensityWhenOn":101,"defaultLed6ColorWhenOff":255,"defaultLed6ColorWhenOn":255,"defaultLed6IntensityWhenOff":0,"defaultLed6IntensityWhenOn":101,"defaultLed7ColorWhenOff":255,"defaultLed7ColorWhenOn":255,"defaultLed7IntensityWhenOff":101,"defaultLed7IntensityWhenOn":101,"defaultLevelLocal":254,"defaultLevelRemote":19,"deviceBindNumber":0,"dimmingMode":"Leading edge","dimmingSpeedDownLocal":126,"dimmingSpeedDownRemote":126,"dimmingSpeedUpLocal":127,"dimmingSpeedUpRemote":8,"doubleTapClearNotifications":"Enabled (Default)","doubleTapDownToParam56":"Disabled","doubleTapUpToParam55":"Disabled","energy":2.22,"fanControlMode":"Disabled","fanLedLevelType":0,"firmwareUpdateInProgressIndicator":"Enabled","highLevelForFanControlMode":254,"higherOutputInNonNeutral":"Disabled (default)","identify":null,"individual_led_effect":null,"internalTemperature":27,"invertSwitch":"No","last_seen":"2025-02-14T08:51:05-05:00","ledBarScaling":"Gen3 method (VZM-style)","ledColorForFanControlMode":255,"ledColorWhenOff":16,"ledColorWhenOn":16,"ledIntensityWhenOff":5,"ledIntensityWhenOn":30,"led_effect":null,"linkquality":181,"loadLevelIndicatorTimeout":"Stay On","localProtection":"Disabled","lowLevelForFanControlMode":63,"maximumLevel":240,"mediumLevelForFanControlMode":128,"minimumLevel":51,"onOffLedMode":"All","outputMode":"Dimmer","overheat":"No Alert","periodicPowerAndEnergyReports":3600,"power":32.2,"powerType":"Neutral","quickStartLevel":254,"quickStartTime":0,"rampRateOffToOnLocal":127,"rampRateOffToOnRemote":127,"rampRateOnToOffLocal":126,"rampRateOnToOffRemote":126,"relayClick":"Disabled (Click Sound On)","remoteProtection":"Disabled","singleTapBehavior":"Old Behavior","smartBulbMode":"Disabled","state":"OFF","stateAfterPowerRestored":255,"switchType":"3-Way Aux Switch","update":{"installed_version":16908818,"latest_version":16908818,"state":"idle"}}'
Info 2025-02-14 08:51:12z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/floor1/diningRoom/chandelier', payload '{"activeEnergyReports":10,"activePowerReports":10,"autoTimerOff":0,"auxSwitchUniqueScenes":"Disabled","bindingOffToOnSyncLevel":"Enabled","brightness":254,"brightnessLevelForDoubleTapDown":2,"brightnessLevelForDoubleTapUp":254,"buttonDelay":"0ms","defaultLed1ColorWhenOff":255,"defaultLed1ColorWhenOn":255,"defaultLed1IntensityWhenOff":0,"defaultLed1IntensityWhenOn":101,"defaultLed2ColorWhenOff":255,"defaultLed2ColorWhenOn":255,"defaultLed2IntensityWhenOff":0,"defaultLed2IntensityWhenOn":101,"defaultLed3ColorWhenOff":255,"defaultLed3ColorWhenOn":255,"defaultLed3IntensityWhenOff":0,"defaultLed3IntensityWhenOn":101,"defaultLed4ColorWhenOff":255,"defaultLed4ColorWhenOn":255,"defaultLed4IntensityWhenOff":0,"defaultLed4IntensityWhenOn":101,"defaultLed5ColorWhenOff":255,"defaultLed5ColorWhenOn":255,"defaultLed5IntensityWhenOff":0,"defaultLed5IntensityWhenOn":101,"defaultLed6ColorWhenOff":255,"defaultLed6ColorWhenOn":255,"defaultLed6IntensityWhenOff":0,"defaultLed6IntensityWhenOn":101,"defaultLed7ColorWhenOff":255,"defaultLed7ColorWhenOn":255,"defaultLed7IntensityWhenOff":101,"defaultLed7IntensityWhenOn":101,"defaultLevelLocal":254,"defaultLevelRemote":19,"deviceBindNumber":0,"dimmingMode":"Leading edge","dimmingSpeedDownLocal":126,"dimmingSpeedDownRemote":126,"dimmingSpeedUpLocal":127,"dimmingSpeedUpRemote":8,"doubleTapClearNotifications":"Enabled (Default)","doubleTapDownToParam56":"Disabled","doubleTapUpToParam55":"Disabled","energy":2.22,"fanControlMode":"Disabled","fanLedLevelType":0,"firmwareUpdateInProgressIndicator":"Enabled","highLevelForFanControlMode":254,"higherOutputInNonNeutral":"Disabled (default)","identify":null,"individual_led_effect":null,"internalTemperature":27,"invertSwitch":"No","last_seen":"2025-02-14T08:51:12-05:00","ledBarScaling":"Gen3 method (VZM-style)","ledColorForFanControlMode":255,"ledColorWhenOff":16,"ledColorWhenOn":16,"ledIntensityWhenOff":5,"ledIntensityWhenOn":30,"led_effect":null,"linkquality":178,"loadLevelIndicatorTimeout":"Stay On","localProtection":"Disabled","lowLevelForFanControlMode":63,"maximumLevel":240,"mediumLevelForFanControlMode":128,"minimumLevel":51,"onOffLedMode":"All","outputMode":"Dimmer","overheat":"No Alert","periodicPowerAndEnergyReports":3600,"power":0,"powerType":"Neutral","quickStartLevel":254,"quickStartTime":0,"rampRateOffToOnLocal":127,"rampRateOffToOnRemote":127,"rampRateOnToOffLocal":126,"rampRateOnToOffRemote":126,"relayClick":"Disabled (Click Sound On)","remoteProtection":"Disabled","singleTapBehavior":"Old Behavior","smartBulbMode":"Disabled","state":"OFF","stateAfterPowerRestored":255,"switchType":"3-Way Aux Switch","update":{"installed_version":16908818,"latest_version":16908818,"state":"idle"}}'
Info 2025-02-14 08:51:13z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/floor1/diningRoom/chandelier', payload '{"action":"config_single","activeEnergyReports":10,"activePowerReports":10,"autoTimerOff":0,"auxSwitchUniqueScenes":"Disabled","bindingOffToOnSyncLevel":"Enabled","brightness":254,"brightnessLevelForDoubleTapDown":2,"brightnessLevelForDoubleTapUp":254,"buttonDelay":"0ms","defaultLed1ColorWhenOff":255,"defaultLed1ColorWhenOn":255,"defaultLed1IntensityWhenOff":0,"defaultLed1IntensityWhenOn":101,"defaultLed2ColorWhenOff":255,"defaultLed2ColorWhenOn":255,"defaultLed2IntensityWhenOff":0,"defaultLed2IntensityWhenOn":101,"defaultLed3ColorWhenOff":255,"defaultLed3ColorWhenOn":255,"defaultLed3IntensityWhenOff":0,"defaultLed3IntensityWhenOn":101,"defaultLed4ColorWhenOff":255,"defaultLed4ColorWhenOn":255,"defaultLed4IntensityWhenOff":0,"defaultLed4IntensityWhenOn":101,"defaultLed5ColorWhenOff":255,"defaultLed5ColorWhenOn":255,"defaultLed5IntensityWhenOff":0,"defaultLed5IntensityWhenOn":101,"defaultLed6ColorWhenOff":255,"defaultLed6ColorWhenOn":255,"defaultLed6IntensityWhenOff":0,"defaultLed6IntensityWhenOn":101,"defaultLed7ColorWhenOff":255,"defaultLed7ColorWhenOn":255,"defaultLed7IntensityWhenOff":101,"defaultLed7IntensityWhenOn":101,"defaultLevelLocal":254,"defaultLevelRemote":19,"deviceBindNumber":0,"dimmingMode":"Leading edge","dimmingSpeedDownLocal":126,"dimmingSpeedDownRemote":126,"dimmingSpeedUpLocal":127,"dimmingSpeedUpRemote":8,"doubleTapClearNotifications":"Enabled (Default)","doubleTapDownToParam56":"Disabled","doubleTapUpToParam55":"Disabled","energy":2.22,"fanControlMode":"Disabled","fanLedLevelType":0,"firmwareUpdateInProgressIndicator":"Enabled","highLevelForFanControlMode":254,"higherOutputInNonNeutral":"Disabled (default)","identify":null,"individual_led_effect":null,"internalTemperature":27,"invertSwitch":"No","last_seen":"2025-02-14T08:51:13-05:00","ledBarScaling":"Gen3 method (VZM-style)","ledColorForFanControlMode":255,"ledColorWhenOff":16,"ledColorWhenOn":16,"ledIntensityWhenOff":5,"ledIntensityWhenOn":30,"led_effect":null,"linkquality":177,"loadLevelIndicatorTimeout":"Stay On","localProtection":"Disabled","lowLevelForFanControlMode":63,"maximumLevel":240,"mediumLevelForFanControlMode":128,"minimumLevel":51,"onOffLedMode":"All","outputMode":"Dimmer","overheat":"No Alert","periodicPowerAndEnergyReports":3600,"power":0,"powerType":"Neutral","quickStartLevel":254,"quickStartTime":0,"rampRateOffToOnLocal":127,"rampRateOffToOnRemote":127,"rampRateOnToOffLocal":126,"rampRateOnToOffRemote":126,"relayClick":"Disabled (Click Sound On)","remoteProtection":"Disabled","singleTapBehavior":"Old Behavior","smartBulbMode":"Disabled","state":"OFF","stateAfterPowerRestored":255,"switchType":"3-Way Aux Switch","update":{"installed_version":16908818,"latest_version":16908818,"state":"idle"}}'
Info 2025-02-14 08:51:13z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/floor1/diningRoom/chandelier/action', payload 'config_single'
Info 2025-02-14 08:51:13z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/floor1/diningRoom/chandelier', payload '{"activeEnergyReports":10,"activePowerReports":10,"autoTimerOff":0,"auxSwitchUniqueScenes":"Disabled","bindingOffToOnSyncLevel":"Enabled","brightness":254,"brightnessLevelForDoubleTapDown":2,"brightnessLevelForDoubleTapUp":254,"buttonDelay":"0ms","defaultLed1ColorWhenOff":255,"defaultLed1ColorWhenOn":255,"defaultLed1IntensityWhenOff":0,"defaultLed1IntensityWhenOn":101,"defaultLed2ColorWhenOff":255,"defaultLed2ColorWhenOn":255,"defaultLed2IntensityWhenOff":0,"defaultLed2IntensityWhenOn":101,"defaultLed3ColorWhenOff":255,"defaultLed3ColorWhenOn":255,"defaultLed3IntensityWhenOff":0,"defaultLed3IntensityWhenOn":101,"defaultLed4ColorWhenOff":255,"defaultLed4ColorWhenOn":255,"defaultLed4IntensityWhenOff":0,"defaultLed4IntensityWhenOn":101,"defaultLed5ColorWhenOff":255,"defaultLed5ColorWhenOn":255,"defaultLed5IntensityWhenOff":0,"defaultLed5IntensityWhenOn":101,"defaultLed6ColorWhenOff":255,"defaultLed6ColorWhenOn":255,"defaultLed6IntensityWhenOff":0,"defaultLed6IntensityWhenOn":101,"defaultLed7ColorWhenOff":255,"defaultLed7ColorWhenOn":255,"defaultLed7IntensityWhenOff":101,"defaultLed7IntensityWhenOn":101,"defaultLevelLocal":254,"defaultLevelRemote":19,"deviceBindNumber":0,"dimmingMode":"Leading edge","dimmingSpeedDownLocal":126,"dimmingSpeedDownRemote":126,"dimmingSpeedUpLocal":127,"dimmingSpeedUpRemote":8,"doubleTapClearNotifications":"Enabled (Default)","doubleTapDownToParam56":"Disabled","doubleTapUpToParam55":"Disabled","energy":2.22,"fanControlMode":"Disabled","fanLedLevelType":0,"firmwareUpdateInProgressIndicator":"Enabled","highLevelForFanControlMode":254,"higherOutputInNonNeutral":"Disabled (default)","identify":null,"individual_led_effect":null,"internalTemperature":27,"invertSwitch":"No","last_seen":"2025-02-14T08:51:13-05:00","ledBarScaling":"Gen3 method (VZM-style)","ledColorForFanControlMode":255,"ledColorWhenOff":16,"ledColorWhenOn":16,"ledIntensityWhenOff":5,"ledIntensityWhenOn":30,"led_effect":null,"linkquality":180,"loadLevelIndicatorTimeout":"Stay On","localProtection":"Disabled","lowLevelForFanControlMode":63,"maximumLevel":240,"mediumLevelForFanControlMode":128,"minimumLevel":51,"onOffLedMode":"All","outputMode":"Dimmer","overheat":"No Alert","periodicPowerAndEnergyReports":3600,"power":0,"powerType":"Neutral","quickStartLevel":254,"quickStartTime":0,"rampRateOffToOnLocal":127,"rampRateOffToOnRemote":127,"rampRateOnToOffLocal":126,"rampRateOnToOffRemote":126,"relayClick":"Disabled (Click Sound On)","remoteProtection":"Disabled","singleTapBehavior":"Old Behavior","smartBulbMode":"Disabled","state":"OFF","stateAfterPowerRestored":255,"switchType":"3-Way Aux Switch","update":{"installed_version":16908818,"latest_version":16908818,"state":"idle"}}'
Info 2025-02-14 08:51:13z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/floor1/diningRoom/chandelier', payload '{"activeEnergyReports":10,"activePowerReports":10,"autoTimerOff":0,"auxSwitchUniqueScenes":"Disabled","bindingOffToOnSyncLevel":"Enabled","brightness":254,"brightnessLevelForDoubleTapDown":2,"brightnessLevelForDoubleTapUp":254,"buttonDelay":"0ms","defaultLed1ColorWhenOff":255,"defaultLed1ColorWhenOn":255,"defaultLed1IntensityWhenOff":0,"defaultLed1IntensityWhenOn":101,"defaultLed2ColorWhenOff":255,"defaultLed2ColorWhenOn":255,"defaultLed2IntensityWhenOff":0,"defaultLed2IntensityWhenOn":101,"defaultLed3ColorWhenOff":255,"defaultLed3ColorWhenOn":255,"defaultLed3IntensityWhenOff":0,"defaultLed3IntensityWhenOn":101,"defaultLed4ColorWhenOff":255,"defaultLed4ColorWhenOn":255,"defaultLed4IntensityWhenOff":0,"defaultLed4IntensityWhenOn":101,"defaultLed5ColorWhenOff":255,"defaultLed5ColorWhenOn":255,"defaultLed5IntensityWhenOff":0,"defaultLed5IntensityWhenOn":101,"defaultLed6ColorWhenOff":255,"defaultLed6ColorWhenOn":255,"defaultLed6IntensityWhenOff":0,"defaultLed6IntensityWhenOn":101,"defaultLed7ColorWhenOff":255,"defaultLed7ColorWhenOn":255,"defaultLed7IntensityWhenOff":101,"defaultLed7IntensityWhenOn":101,"defaultLevelLocal":254,"defaultLevelRemote":19,"deviceBindNumber":0,"dimmingMode":"Leading edge","dimmingSpeedDownLocal":126,"dimmingSpeedDownRemote":126,"dimmingSpeedUpLocal":127,"dimmingSpeedUpRemote":8,"doubleTapClearNotifications":"Enabled (Default)","doubleTapDownToParam56":"Disabled","doubleTapUpToParam55":"Disabled","energy":2.22,"fanControlMode":"Disabled","fanLedLevelType":0,"firmwareUpdateInProgressIndicator":"Enabled","highLevelForFanControlMode":254,"higherOutputInNonNeutral":"Disabled (default)","identify":null,"individual_led_effect":null,"internalTemperature":27,"invertSwitch":"No","last_seen":"2025-02-14T08:51:13-05:00","ledBarScaling":"Gen3 method (VZM-style)","ledColorForFanControlMode":255,"ledColorWhenOff":16,"ledColorWhenOn":16,"ledIntensityWhenOff":5,"ledIntensityWhenOn":30,"led_effect":null,"linkquality":180,"loadLevelIndicatorTimeout":"Stay On","localProtection":"Disabled","lowLevelForFanControlMode":63,"maximumLevel":240,"mediumLevelForFanControlMode":128,"minimumLevel":51,"onOffLedMode":"All","outputMode":"Dimmer","overheat":"No Alert","periodicPowerAndEnergyReports":3600,"power":0,"powerType":"Neutral","quickStartLevel":254,"quickStartTime":0,"rampRateOffToOnLocal":127,"rampRateOffToOnRemote":127,"rampRateOnToOffLocal":126,"rampRateOnToOffRemote":126,"relayClick":"Disabled (Click Sound On)","remoteProtection":"Disabled","singleTapBehavior":"Old Behavior","smartBulbMode":"Disabled","state":"ON","stateAfterPowerRestored":255,"switchType":"3-Way Aux Switch","update":{"installed_version":16908818,"latest_version":16908818,"state":"idle"}}'
Info 2025-02-14 08:51:13z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/floor1/diningRoom/chandelier', payload '{"activeEnergyReports":10,"activePowerReports":10,"autoTimerOff":0,"auxSwitchUniqueScenes":"Disabled","bindingOffToOnSyncLevel":"Enabled","brightness":19,"brightnessLevelForDoubleTapDown":2,"brightnessLevelForDoubleTapUp":254,"buttonDelay":"0ms","defaultLed1ColorWhenOff":255,"defaultLed1ColorWhenOn":255,"defaultLed1IntensityWhenOff":0,"defaultLed1IntensityWhenOn":101,"defaultLed2ColorWhenOff":255,"defaultLed2ColorWhenOn":255,"defaultLed2IntensityWhenOff":0,"defaultLed2IntensityWhenOn":101,"defaultLed3ColorWhenOff":255,"defaultLed3ColorWhenOn":255,"defaultLed3IntensityWhenOff":0,"defaultLed3IntensityWhenOn":101,"defaultLed4ColorWhenOff":255,"defaultLed4ColorWhenOn":255,"defaultLed4IntensityWhenOff":0,"defaultLed4IntensityWhenOn":101,"defaultLed5ColorWhenOff":255,"defaultLed5ColorWhenOn":255,"defaultLed5IntensityWhenOff":0,"defaultLed5IntensityWhenOn":101,"defaultLed6ColorWhenOff":255,"defaultLed6ColorWhenOn":255,"defaultLed6IntensityWhenOff":0,"defaultLed6IntensityWhenOn":101,"defaultLed7ColorWhenOff":255,"defaultLed7ColorWhenOn":255,"defaultLed7IntensityWhenOff":101,"defaultLed7IntensityWhenOn":101,"defaultLevelLocal":254,"defaultLevelRemote":19,"deviceBindNumber":0,"dimmingMode":"Leading edge","dimmingSpeedDownLocal":126,"dimmingSpeedDownRemote":126,"dimmingSpeedUpLocal":127,"dimmingSpeedUpRemote":8,"doubleTapClearNotifications":"Enabled (Default)","doubleTapDownToParam56":"Disabled","doubleTapUpToParam55":"Disabled","energy":2.22,"fanControlMode":"Disabled","fanLedLevelType":0,"firmwareUpdateInProgressIndicator":"Enabled","highLevelForFanControlMode":254,"higherOutputInNonNeutral":"Disabled (default)","identify":null,"individual_led_effect":null,"internalTemperature":27,"invertSwitch":"No","last_seen":"2025-02-14T08:51:13-05:00","ledBarScaling":"Gen3 method (VZM-style)","ledColorForFanControlMode":255,"ledColorWhenOff":16,"ledColorWhenOn":16,"ledIntensityWhenOff":5,"ledIntensityWhenOn":30,"led_effect":null,"linkquality":180,"loadLevelIndicatorTimeout":"Stay On","localProtection":"Disabled","lowLevelForFanControlMode":63,"maximumLevel":240,"mediumLevelForFanControlMode":128,"minimumLevel":51,"onOffLedMode":"All","outputMode":"Dimmer","overheat":"No Alert","periodicPowerAndEnergyReports":3600,"power":0,"powerType":"Neutral","quickStartLevel":254,"quickStartTime":0,"rampRateOffToOnLocal":127,"rampRateOffToOnRemote":127,"rampRateOnToOffLocal":126,"rampRateOnToOffRemote":126,"relayClick":"Disabled (Click Sound On)","remoteProtection":"Disabled","singleTapBehavior":"Old Behavior","smartBulbMode":"Disabled","state":"ON","stateAfterPowerRestored":255,"switchType":"3-Way Aux Switch","update":{"installed_version":16908818,"latest_version":16908818,"state":"idle"}}'
Info 2025-02-14 08:51:13z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/floor1/diningRoom/chandelier', payload '{"activeEnergyReports":10,"activePowerReports":10,"autoTimerOff":0,"auxSwitchUniqueScenes":"Disabled","bindingOffToOnSyncLevel":"Enabled","brightness":19,"brightnessLevelForDoubleTapDown":2,"brightnessLevelForDoubleTapUp":254,"buttonDelay":"0ms","defaultLed1ColorWhenOff":255,"defaultLed1ColorWhenOn":255,"defaultLed1IntensityWhenOff":0,"defaultLed1IntensityWhenOn":101,"defaultLed2ColorWhenOff":255,"defaultLed2ColorWhenOn":255,"defaultLed2IntensityWhenOff":0,"defaultLed2IntensityWhenOn":101,"defaultLed3ColorWhenOff":255,"defaultLed3ColorWhenOn":255,"defaultLed3IntensityWhenOff":0,"defaultLed3IntensityWhenOn":101,"defaultLed4ColorWhenOff":255,"defaultLed4ColorWhenOn":255,"defaultLed4IntensityWhenOff":0,"defaultLed4IntensityWhenOn":101,"defaultLed5ColorWhenOff":255,"defaultLed5ColorWhenOn":255,"defaultLed5IntensityWhenOff":0,"defaultLed5IntensityWhenOn":101,"defaultLed6ColorWhenOff":255,"defaultLed6ColorWhenOn":255,"defaultLed6IntensityWhenOff":0,"defaultLed6IntensityWhenOn":101,"defaultLed7ColorWhenOff":255,"defaultLed7ColorWhenOn":255,"defaultLed7IntensityWhenOff":101,"defaultLed7IntensityWhenOn":101,"defaultLevelLocal":254,"defaultLevelRemote":19,"deviceBindNumber":0,"dimmingMode":"Leading edge","dimmingSpeedDownLocal":126,"dimmingSpeedDownRemote":126,"dimmingSpeedUpLocal":127,"dimmingSpeedUpRemote":8,"doubleTapClearNotifications":"Enabled (Default)","doubleTapDownToParam56":"Disabled","doubleTapUpToParam55":"Disabled","energy":2.22,"fanControlMode":"Disabled","fanLedLevelType":0,"firmwareUpdateInProgressIndicator":"Enabled","highLevelForFanControlMode":254,"higherOutputInNonNeutral":"Disabled (default)","identify":null,"individual_led_effect":null,"internalTemperature":27,"invertSwitch":"No","last_seen":"2025-02-14T08:51:13-05:00","ledBarScaling":"Gen3 method (VZM-style)","ledColorForFanControlMode":255,"ledColorWhenOff":16,"ledColorWhenOn":16,"ledIntensityWhenOff":5,"ledIntensityWhenOn":30,"led_effect":null,"linkquality":179,"loadLevelIndicatorTimeout":"Stay On","localProtection":"Disabled","lowLevelForFanControlMode":63,"maximumLevel":240,"mediumLevelForFanControlMode":128,"minimumLevel":51,"onOffLedMode":"All","outputMode":"Dimmer","overheat":"No Alert","periodicPowerAndEnergyReports":3600,"power":0,"powerType":"Neutral","quickStartLevel":254,"quickStartTime":0,"rampRateOffToOnLocal":127,"rampRateOffToOnRemote":127,"rampRateOnToOffLocal":126,"rampRateOnToOffRemote":126,"relayClick":"Disabled (Click Sound On)","remoteProtection":"Disabled","singleTapBehavior":"Old Behavior","smartBulbMode":"Disabled","state":"ON","stateAfterPowerRestored":255,"switchType":"3-Way Aux Switch","update":{"installed_version":16908818,"latest_version":16908818,"state":"idle"}}'
Info 2025-02-14 08:51:18z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/floor1/diningRoom/chandelier', payload '{"activeEnergyReports":10,"activePowerReports":10,"autoTimerOff":0,"auxSwitchUniqueScenes":"Disabled","bindingOffToOnSyncLevel":"Enabled","brightness":19,"brightnessLevelForDoubleTapDown":2,"brightnessLevelForDoubleTapUp":254,"buttonDelay":"0ms","defaultLed1ColorWhenOff":255,"defaultLed1ColorWhenOn":255,"defaultLed1IntensityWhenOff":0,"defaultLed1IntensityWhenOn":101,"defaultLed2ColorWhenOff":255,"defaultLed2ColorWhenOn":255,"defaultLed2IntensityWhenOff":0,"defaultLed2IntensityWhenOn":101,"defaultLed3ColorWhenOff":255,"defaultLed3ColorWhenOn":255,"defaultLed3IntensityWhenOff":0,"defaultLed3IntensityWhenOn":101,"defaultLed4ColorWhenOff":255,"defaultLed4ColorWhenOn":255,"defaultLed4IntensityWhenOff":0,"defaultLed4IntensityWhenOn":101,"defaultLed5ColorWhenOff":255,"defaultLed5ColorWhenOn":255,"defaultLed5IntensityWhenOff":0,"defaultLed5IntensityWhenOn":101,"defaultLed6ColorWhenOff":255,"defaultLed6ColorWhenOn":255,"defaultLed6IntensityWhenOff":0,"defaultLed6IntensityWhenOn":101,"defaultLed7ColorWhenOff":255,"defaultLed7ColorWhenOn":255,"defaultLed7IntensityWhenOff":101,"defaultLed7IntensityWhenOn":101,"defaultLevelLocal":254,"defaultLevelRemote":19,"deviceBindNumber":0,"dimmingMode":"Leading edge","dimmingSpeedDownLocal":126,"dimmingSpeedDownRemote":126,"dimmingSpeedUpLocal":127,"dimmingSpeedUpRemote":8,"doubleTapClearNotifications":"Enabled (Default)","doubleTapDownToParam56":"Disabled","doubleTapUpToParam55":"Disabled","energy":2.22,"fanControlMode":"Disabled","fanLedLevelType":0,"firmwareUpdateInProgressIndicator":"Enabled","highLevelForFanControlMode":254,"higherOutputInNonNeutral":"Disabled (default)","identify":null,"individual_led_effect":null,"internalTemperature":27,"invertSwitch":"No","last_seen":"2025-02-14T08:51:18-05:00","ledBarScaling":"Gen3 method (VZM-style)","ledColorForFanControlMode":255,"ledColorWhenOff":16,"ledColorWhenOn":16,"ledIntensityWhenOff":5,"ledIntensityWhenOn":30,"led_effect":null,"linkquality":181,"loadLevelIndicatorTimeout":"Stay On","localProtection":"Disabled","lowLevelForFanControlMode":63,"maximumLevel":240,"mediumLevelForFanControlMode":128,"minimumLevel":51,"onOffLedMode":"All","outputMode":"Dimmer","overheat":"No Alert","periodicPowerAndEnergyReports":3600,"power":3,"powerType":"Neutral","quickStartLevel":254,"quickStartTime":0,"rampRateOffToOnLocal":127,"rampRateOffToOnRemote":127,"rampRateOnToOffLocal":126,"rampRateOnToOffRemote":126,"relayClick":"Disabled (Click Sound On)","remoteProtection":"Disabled","singleTapBehavior":"Old Behavior","smartBulbMode":"Disabled","state":"ON","stateAfterPowerRestored":255,"switchType":"3-Way Aux Switch","update":{"installed_version":16908818,"latest_version":16908818,"state":"idle"}}'
Info 2025-02-14 08:51:27z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/floor1/diningRoom/chandelier', payload '{"activeEnergyReports":10,"activePowerReports":10,"autoTimerOff":0,"auxSwitchUniqueScenes":"Disabled","bindingOffToOnSyncLevel":"Enabled","brightness":19,"brightnessLevelForDoubleTapDown":2,"brightnessLevelForDoubleTapUp":254,"buttonDelay":"0ms","defaultLed1ColorWhenOff":255,"defaultLed1ColorWhenOn":255,"defaultLed1IntensityWhenOff":0,"defaultLed1IntensityWhenOn":101,"defaultLed2ColorWhenOff":255,"defaultLed2ColorWhenOn":255,"defaultLed2IntensityWhenOff":0,"defaultLed2IntensityWhenOn":101,"defaultLed3ColorWhenOff":255,"defaultLed3ColorWhenOn":255,"defaultLed3IntensityWhenOff":0,"defaultLed3IntensityWhenOn":101,"defaultLed4ColorWhenOff":255,"defaultLed4ColorWhenOn":255,"defaultLed4IntensityWhenOff":0,"defaultLed4IntensityWhenOn":101,"defaultLed5ColorWhenOff":255,"defaultLed5ColorWhenOn":255,"defaultLed5IntensityWhenOff":0,"defaultLed5IntensityWhenOn":101,"defaultLed6ColorWhenOff":255,"defaultLed6ColorWhenOn":255,"defaultLed6IntensityWhenOff":0,"defaultLed6IntensityWhenOn":101,"defaultLed7ColorWhenOff":255,"defaultLed7ColorWhenOn":255,"defaultLed7IntensityWhenOff":101,"defaultLed7IntensityWhenOn":101,"defaultLevelLocal":254,"defaultLevelRemote":19,"deviceBindNumber":0,"dimmingMode":"Leading edge","dimmingSpeedDownLocal":126,"dimmingSpeedDownRemote":126,"dimmingSpeedUpLocal":127,"dimmingSpeedUpRemote":8,"doubleTapClearNotifications":"Enabled (Default)","doubleTapDownToParam56":"Disabled","doubleTapUpToParam55":"Disabled","energy":2.22,"fanControlMode":"Disabled","fanLedLevelType":0,"firmwareUpdateInProgressIndicator":"Enabled","highLevelForFanControlMode":254,"higherOutputInNonNeutral":"Disabled (default)","identify":null,"individual_led_effect":null,"internalTemperature":27,"invertSwitch":"No","last_seen":"2025-02-14T08:51:27-05:00","ledBarScaling":"Gen3 method (VZM-style)","ledColorForFanControlMode":255,"ledColorWhenOff":16,"ledColorWhenOn":16,"ledIntensityWhenOff":5,"ledIntensityWhenOn":30,"led_effect":null,"linkquality":180,"loadLevelIndicatorTimeout":"Stay On","localProtection":"Disabled","lowLevelForFanControlMode":63,"maximumLevel":240,"mediumLevelForFanControlMode":128,"minimumLevel":51,"onOffLedMode":"All","outputMode":"Dimmer","overheat":"No Alert","periodicPowerAndEnergyReports":3600,"power":3,"powerType":"Neutral","quickStartLevel":254,"quickStartTime":0,"rampRateOffToOnLocal":127,"rampRateOffToOnRemote":127,"rampRateOnToOffLocal":126,"rampRateOnToOffRemote":126,"relayClick":"Disabled (Click Sound On)","remoteProtection":"Disabled","singleTapBehavior":"Old Behavior","smartBulbMode":"Disabled","state":"ON","stateAfterPowerRestored":255,"switchType":"3-Way Aux Switch","update":{"installed_version":16908818,"latest_version":16908818,"state":"idle"}}'
Nudging this thread back to life. I’ve continued experimenting with this dimmer and my aux switch. No change here no matter what I have tried. Did your testing @EricM_Inovelli reveal anything else?
Sorry @rpulivella, I haven’t forgotten about you. I went to run some tests last week on your findings and noticed my switch was at an earlier firmware. I then updated it and then didn’t find my way back to the issue and have been busy yesterday and today. I will hopefully get to it tomorrow and will have some information to add to the thread.
All good. I’m in no rush. Please let me know how/if I can be helpful in the process. It seems unlikely to be a hardware problem but instead an obscure and rare firmware bug?
Ok, I just did a bunch of testing. TBH I hate testing all the dimming and ramp rates lol. I have done it dozens of times. I made sure I had the latest firmware (2.18) and then did a factory reset to make sure there were not any memory cobwebs sticking around.
I went through each setting one at a time and verified a couple different settings. Then, after all of them were set to something other than the default (sync), I went through and tested them again.
Then I set everything back to default and tested the specific scenario you had in the first post. I set RampRateOnToOffRemote to 120 and set it to use an aux switch. Tried a few different settings too and they all seemed to work. So it is still a mystery.
Do you run the dev version of Z2M by chance? If so, can you upgrade to the latest dev (because that is what I am testing with). Sometimes the ramp rate or dimming settings seem off because a hub will send a “move to off” with a duration instead of just an off (without a duration). That is the only thing I can think of right now . . . other than the switch being defective somehow.
