I have one inovelli blue 2-1 switch set to dimming mode, and for some reason whenever I press the up paddle, the light level goes from 0% to 25% to 50% to 100% with each press. When I press the down paddle it goes in the reverse order. None of my other switches have this issue, and I believe they’re all configured the same way. Is there some config I’m missing that enables this behaviour?
try “single tap behavior” “old behavior”. i ran into the same issue and it drove me nuts.
Couldn’t find “single tap behavior” but a factory reset fixed the issue. Strange because it seems like a “feature.”
Parameter 120. The default is the old style so factory resetting accomplished the same thing.
