Inovelli Dimmer with Inovelli bulbs not working
Yes, those settings look good :slight_smile:
Is it working out for you?
You dont need both of these if you want the dimmer to show the actual brightness on the LED bar, just FYI.
The on/off seems to work well, dimming is a bit flaky, but that might just messing with the dimming speed.
I did turn 52-smart bulb to No Selection and Disable Local Control - No
On the association tool I used 2,3 and 4.
State Variables
  • parameter2value : 101
  • parameter5value : 1
  • parameter21value : 1
  • actualAssociation4 : [2F, 37, 38, 39]
  • actualAssociation3 : [2F, 37, 38, 39]
  • parameter10value : 0
  • parameter8value : 0
  • oldLabel : dimmer_inovelli_Master Bedroom Fan Lights
  • parameter19value : 3600
  • desiredAssociation2 : [37, 38, 39]
  • parameter13value : 212
  • desiredAssociation1 : [2E, 2F, 30]
  • desiredAssociation4 : [2F, 37, 38, 39]
  • desiredAssociation3 : [2F, 37, 38, 39]
  • parameter16value : 0
  • rfProtectionState : 0
  • parameter22value : 0
  • lastRan : 1641508766786
  • parameter3value : 101
  • parameter52value : 0
  • parameter9value : 0
  • parameter6value : 99
  • parameter17value : 3
  • localProtectionState : 0
  • parameter14value : 10
  • parameter50value : 5
  • parameter11value : 0
  • associationGroups : 4
  • parameter51value : 1
  • parameter7value : 0
  • parameter15value : 10
  • parameter4value : 101
  • parameter18value : 10
  • needfwUpdate : false
  • defaultG3 : []
  • actualAssociation2 : [37, 38, 39]
  • parameter1value : 3
  • defaultG2 : []
  • actualAssociation1 : [01, 2E, 2F, 30]
  • defaultG1 : [01]
  • parameter12value : 15
  • parameter20value : 10
The RGB bulbs need constant power. Set param 52 to 2.
Shoot sorry. I meant you don’t need them both on, only one. Recommend 52 to 2.
Gah, I continue to have issues with one dimmer to many bulbs not correctly firing a frustrating amount. Can someone validate they grouped 2, 3, and 4 from dimmer to bulbs and that is working for them?:
WAF is reduced right now!
@stu1811 @Bry
Which bulbs? LZW42? I don’t have group 2 in my setup. Mine is a single LZW31-SN to 3x LZW42.
Edit: Dimmer is 1.61 and bulbs are 1.31
I am using Group 2,3 and 4. I also had to change some setting on the switch to get it to flawlessly work.
Preferences:
1 = 0
2 =1
3 =1
4 =0
52. Smart Bulb Mode = Smart Bulb
Disable Local Control = No
Gotta defer to the others. All my bulbs are Zigbee, so I don’t use associations.
@stu1811 should know. He’s the one with the Inovelli mug . . . :rofl: :rofl: :rofl:
