Inovelli Red LZW30-SN Issues turning back on
I am using Home Assistant Z-wave JS
Red Switch FW 1.21
I am trying to set parametere 22 to 0 and its now shown anywhere in the config. I also cant set it through custom config. I am trying to solve an issue im having the light keeps toggling back on when i turn it off. It wired wired with the Red switch in my main hall and the 2 way dumb part in the garage. This controls my garage outside lighting which a simple automation to turn ona nd off at sunrise sunset wont work because the lights toggle themselves back dependings ont eh aux switch
Can you confirm you have the LZW30-SN, which is the on/off SWITCH, not the dimmer? There is no parameter 22 for the LZW30-SN, which would explain why you can’t find it.
it is just the on/off switch . Is there not a setting for what the aux is (dumb switch). Right now i had to tape the AUX switch int he garage to on (tape to prevent wife or me accidently switching) if its in off position it ruins the Innovelli switch , thats where i noticed it would affect it toggling back on its own. All works fine when that dumb switch is left in the ON position.
There is no parameter to select the switch type. The switch is supposed to auto detect whether or not it’s a two or three way and the switch type.
You can try changing Parameter 13, Special load Type. This is supposed to help when the other switch is not detected properly.
From the firmware change log: P13 can be used in certain 3-way dumb switch setups where the load is confusing the switch as to which state it should be in. In other words, if your On/Off switch is having trouble detecting your Dumb switch, please turn on this parameter.
If that doesn’t work I would double check your wiring.
Ya I tried that one it just made the “toggle back* way faster instead of a few seconds delay where the light will go back on it would be instant.
