The equipment:
Inovelli Red on/off Switch
GE Add-On Switch
A single light in the hallway controlled by two light switches.
I thought that I could use the Inovelli On/Off switch with a GE add on switch. But here is my confusion.
Junction box 1 - three-wire cables coming in. One with a red traveler and two without (just black/white/copper).
Junction box 2 - single wire cable with red traveler.
The GE Add on only has two terminals, traveler and neutral. I cannot find a schematic anywhere that shows me being able to run a three-way with the GE Switch only having a traveler and neutral.
Junction 1
Wire Cable 1 - Line (120v)(black) wire nut to cable 2 white
- Neutral (white) wire nut to Cable 3 white
Wire Cable 2 - Black to bottom left of switch 1
- White wire nut to Line (Cable 1 black)
- Red to Switch 1 bottom right
Wire Cable 3 - Black and white (I assume this goes to the light)
- Black to Switch 1 top right
- white - wire nut to cable 1 white
Junction 2 - single cable
- white to switch bottom right
- black to switch top right
- red to switch bottom left
Can I use the Inovelli and the GE or do I need to get a different aux / dumb switch?
Thanks
Chuck
