I’m troubleshooting an Inovelli Blue Series mmWave Presence Dimmer Switch (VZM32-SN) and I’m stumped.
The switch powers up, pairs to ZHA perfectly, and I can control it from Home Assistant. LED bar works, dimming state changes, etc. But the switch never energizes the load.
What I’ve tried:
Factory reset
Tried 2 different VZM32-SN switches
Single pole setup
Neutral connected properly
Line to neutral = 123V
Line to ground = 124V
Load to neutral = only ~1.9V regardless of ON/OFF or dim level - Measuring directly at the switch terminals
Smart bulb mode disabled
Output set to on/off and dimmer modes
Different LED fixtures tested (20W LEDs and normal LED bulbs)
Even with no wire attached to the load terminal, I still only measure ~1.9V from LOAD terminal to neutral with the switch on. So the switch itself never seems to drive the output terminal.
Old zwave switch worked fine with the same wiring (although different terminals on the switch)
I’m hoping someone has some ideas for me
Edit: the power_type parameter reads true
