Inovelli White Dimmer Home Assistant automation transitions not working
I installed a Inovelli White dimmer and I have it working successfully with Home Assistant (2025.12.3) in general however if I specify a transition time in an automation to change the level of the dimmer over a period of time the transition period is ignored and the switch goes to the new level immediately. Does the White switch support transition periods? Or is this more likely an issue in the Matter implementation in Home Assistant?
Below is an example of the Home Assistant action I am using.
action: light.turn_on
data:
transition: 30
brightness_pct: 50
target:
entity_id: light.kitchen_switch
