Hi everyone,
It was minus 10 degrees Fahrenheit last night here in Pittsburgh Pennsylvania.
I have three Blue Series dimmers inside the house but on an exterior wall. When I woke up this morning two of them were slow blinking red and light control was sporadic (they would turn the lights on…sometimes).
The two that were blinking red were both part of separate three-way switch setups and the other switch for both seemed to work fine. Both switches were controllable via Home Assistant.
The internal temperature of one switch is 59 degrees F and the other is 60.8 degrees F, but that doesn’t seem legit because I looked at the temperature history of both in Home Assistant and neither appears to have changed over the past month and there were only a couple of data points.
I took off the cover plate to pull the air gap switch and the switches were VERY cold and there was definitely a cold draft coming in (which I guess is another problem I need to solve
I pulled the air gap on them and both are now behaving normally.
I’ve never seen this behavior before.
So…is it possible that the switches got so cold that they stopped working?
Thanks.
