Issue Setting Ramp Rate on LZW31 Dimmer
I am using Home Assistant to make these parameter changes. I am able to successfully modify some of the dimmer parameters using the zwave.set_config_parameter service (like minimum dim level) however I am not seeing the effects of the changes to some of the parameters. Here is what gets returned in the zwave log when attempting to modify the ZWave ramp rate (4). I was able to get parameter 3 to update after a few attempts… What am I missing?
2020-01-08 03:01:28.564 Info, Node008, Configuration::Set - Parameter=4, Value=5 Size=1
2020-01-08 03:01:28.565 Detail, Node008, Queuing (Send) ConfigurationCmd_Set (Node=8): 0x01, 0x0c, 0x00, 0x13, 0x08, 0x05, 0x70, 0x04, 0x04, 0x01, 0x05, 0x25, 0x74, 0xc8
2020-01-08 03:01:28.565 Info, Node008, Sending (Send) message (Callback ID=0x74, Expected Reply=0x13) - ConfigurationCmd_Set (Node=8): 0x01, 0x0c, 0x00, 0x13, 0x08, 0x05, 0x70, 0x04, 0x04, 0x01, 0x05, 0x25, 0x74, 0xc8
2020-01-08 03:01:28.571 Detail, Node008, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-01-08 03:01:28.571 Detail, Node008, ZW_SEND_DATA delivered to Z-Wave stack
2020-01-08 03:01:28.625 Detail, Node008, Received: 0x01, 0x05, 0x00, 0x13, 0x74, 0x00, 0x9d
2020-01-08 03:01:28.625 Detail, Node008, ZW_SEND_DATA Request with callback ID 0x74 received (expected 0x74)
2020-01-08 03:01:28.625 Info, Node008, Request RTT 60 Average Request RTT 79
2020-01-08 03:01:28.625 Detail, Expected callbackId was received
2020-01-08 03:01:28.625 Detail, Expected reply was received
2020-01-08 03:01:28.625 Detail, Message transaction complete
2020-01-08 03:01:28.626 Detail, Node008, Removing current message
Has anyone else had this issue or is it just me? I’m going to upgrade to HomeAssistant v107.7 from v104.2 and see if that fixes things somehow.
Hey @belgian_style – sorry to resurrect an old topic, but I wanted to see if you were able to figure this one out?
