I have inovelli switches throughout my home. I participated in beta programs here; I love the products. I have other red series dimmers elsewhere (some with dimming bulbs, others used in a 3 way config) with no issues. The ones that are with dimming bulbs I had to play around a bit with bulb brands as well as min/max values but I eventually got everything where I wanted it.
Above my shower, I have a single led adjustable wafer made by lithonia (Lithonia Lighting WF6 ADJ LED 30K40K50K 90CRI MW M6 Adjustable Gimbal Wafer Downlight, Ultra Thin Round Trim, Switchable Color Temperature, 6-Inch, Matte White - Amazon.com) so it’s not necessarily an “off brand.” It is listed as being dimmable.
I currently have the following configuration settings: (only those I changed..and I have these same settings elsewhere but different bulbs)
dimming speed 0
dimming speed from switch 2
ramp rate 0
ramp rate from switch 2
minimum level 10
maximum level 99
default level zwave 99
default level local 99
state after power restored 99
ac power type neutral
switch type load only
The light turns on and off immediately as I want it and is at full brightness. Dimming though, is where things get wierd. In general, if I dim down to between 1-35% (either at the physical switch or through smartthings) it dims down fine. Between 35-55% the light strobes. 55%-99% the light is fine. So it has a strobing middle section only which I have never seen before. Where I had issues with other lights was if I went too low only they would strobe. Do I need to play around more with my settings? I tried raising the min to 45% but it didn’t really change anything. I tried setting default to 55 instead of 99 and this caused it to strobe at 55%-99%.
