LED Bar Based on Brightness of Another Switch
I’m trying to remap some switches so that I effectively changed the locations of which switch controls what.
I’ve turned on local protection for switch A, set up automation so that this operates switch B. A itself is operated by a different switch C. This all works in terms of control, but the LED indicator bar on this is not quite right.
I don’t want A’s LED bar to display itself, instead, it should be displaying the state of B.
I don’t see any option to disable the LED bar indicator in ZHA Home Assistant. I see that there’s notifications but it doesn’t appear that I can control the LED “length” to show the brightness of B.
Is there some hidden configs or way I can change the LED bar?
I can issue notification to LED based on the other light switch state (no animation though I think), but if the current light switch is turned on and off, the notification is briefly ignored while the LEDs perform the local switches on/off animation.
Is there some way to turn that off?
