Light or lazy press issues
Not sure what to call the issue but I’ve referred it to “lazy touch” and lately I’ve paid way more attention to my press to the white series switches.
The issue is most presses of the switch to turn on, if not a firm middle of switch press, switch doesn’t respond. Ive noticed even a firmer press on or near the edge does not “switch on”. Very frustrating when you’re walking in a room or late at night and casually press the switch and nothing happens..
Anyone else experience this and is it just the white series? I have about 30 and all are the same issue.
Hi there,
Thank you for reaching out about this issue. Are you able to post a video in this thread, or message me directly with one/a link to one, so I can take a look at the issue you’re having?
Thank you!
I’ve had the same issue with my white series dimmers. Light or quick touches did not activate the switch. I changed the LED switch color to a different color when “on” so that I could easily confirm when the switch detected a press. I sort of trained my presses to be firmer and slightly slower and this seems to activate the switch more consistently.
Hi there,
Is this happening with all of your White Series switches are just a few? Do you have another version of our devices (Blue or Red series) that are having the same issue?
I see now that this happens occasionally when I click on the top paddle and I’m also unintentionally clicking on the configuration button at the same time. The switches that are positioned where the configuration button is between me and the paddle are the most prone to this.
It might be helpful if the top paddle activation “ignores” the simultaneous configuration click so the load is activated nonetheless.
On another brief note, it’s great to be able to configure some parameters for the white Inovelli switches on the Homey (Pro) App. Please continue to add more!
I’ve had similar issues - except sometimes I find myself accidentally double-tapping (when you don’t press hard enough and try to course-correct), which also doesn’t turn the light on. There’s something weird with the paddle being too elastic.
Hi there,
Have you had any luck with removing/re-adding the switch’s paddle to see if your switch registers button presses better?
