LZW30 4-way with two AUX01 - possible?
Hi, I have a LZW30 (“Gen 2 Black”) that I’d like to use in a 4-way configuration. I have two AUX01 switches as well. In my case I have line and load at opposite ends. In the wiring diagrams I see a configuration that looks appropriate, but it calls out GE auxiliary switches. Can the two Inovelli AUX01 be used, and if so what would the wiring look like?
PS: the tag feature seems to require me to enter vtm131mr - it’s the only option. Weird.
Yeah, we know, but apparently it’s not kicking in for everyone.
The Inovelli and GE aux switches are interchangeable. So you can use the same wiring diagram.
As Bry mentioned, it is possible… and if desired, you can even place the master switch in any of the boxes if you’d like the LEDs in a particular location, due to the fact that the neutral is also being carried through with the travelers.
The diagram shows carrying the Load through from the first box to the last box, along with the traveler, but if you want an AUX switch in the first box, you can instead carry the Line to the next box in line (or even the last box) and then switch to carrying the Load to the last box feeding the light.
If you have no preference though, just follow the supplied diagram.
Great thank you Bry and Koadic.
