LZW30 - reading commands from Home Assistant with relay off?
I have the base model on/off switch and I’ve turned off the relay so that the thing it’s wired to is always on. How can I get Home Assistant to interpret the up and down commands as being pressed? For example, the LZW31-SN dimmer with scenes sends scene commands, where 2 means up and 1 means down, and 7680 means 1x taps, 7860 means 2x taps, etc. The LZW30 doesn’t have scenes though. So what message is sent when I tap up once? Or down?
Hey @zeekaran – sorry to resurrect this thread a year later, but I’m going through the forum to clean it up a bit.
Were you ever able to figure this one out?
Yes! All good now. A lot has changed since then in HA, including going through three total Z-wave managers, and the commands going from opaque/arbitrary numbers like 7680 to just 1 through 5 representing the tap amounts. Then I got it all figured out in NodeRed.
I’m running into difficulty in node red picking up button presses or holds. What did you do to get it to work? Have multiple red series devices with no issue
