So I picked up the red series because of the scene control. But I want to use node red to control that. How do I get node red to see that I have pressed up on the paddle 3 times ( and not that I just tried to turn the light on 3 times) ?
Am I missing something simple? I’ve went through a bunch of faqs but cant find anything.
If you are on the built-in zwave integration, you need to make the adjustments to the config files if you haven’t already. This I want to say is the best route to go about it.
So I have the event triggering but its not making it past the “SWITCH” node? Why? See pics. I have debug node attached and when I double tapped down, it triggered it but the other switch did turn off.
So I figured it out, I had to edit the subflow. But why? Why did I have to change it to look at scene_data for? Why isnt mine outputting a scene_value_id as the subflow was originally looking for?
I believe its due to the way you have zwave integrated in HomeAssistant. I use the OpenZWave integration and am able to use the scene_value_id in NodeRed.
