All wave functions are working fine and I can control the switch but the local button no longer works. I have tried pulling the air gap and compared switch settings to other working switches and cannot find an answer.
Is local control disabled? 8X on the config. If it flashes green, you have just reenabled local control. If it flashes red, you have just disabled local control.
Tldr 8x on config so it turns green.
I knew it had to be something simple. That worked. Can this be toggled via zwave setting or only locally?
You should be able to toggle it from your hub. What hub are you using?
