Hey guys,
I have a ton of LZW31-SN (the dimmer series) in my house and have no issues with them.
I just bought one LZW30-SN (the on/off series) for a room that the dimmer won’t work in (because it has a ceiling fan).
I installed this driver: Hubitat/Drivers/inovelli-switch-red-series-lzw30-sn.src at master · InovelliUSA/Hubitat · GitHub
The problem I am having is that when I go into Inovelli Scene Creator, which is an app I use within Hubitat, and specify this device, it says: The selected button device did not report the number of buttons it has. Please specify in the Advanced Config section below.
I get the same thing when I try to use Rule Machine and add a button or button device. I ensured the switch is using the driver that I specified earlier in the device setting. I do not have this problem with my other LZW31-SN switches. Is this a common issue with the LZW30-SN and if not, any ideas how to fix?
Thanks,
Chris
