I need to get to option 13 to enable my GE aux switch but can’t get the yellow flashing feedback to acknowledge any config setting level above 5. Demonstrated here: https://youtu.be/ltr4dG8KZ4M
My understanding is this should be a drop-in replacement for the Enbrighten switch that was there before (after setting option 13).
Parameter 13 on the switch pertains to a special setting for certain load types like T-8. I don’t think that’s what you are looking for. Unlike the dimmer, the switch is supposed to auto-detect the type of connection, 2-way, 3-way, etc and autoconfigure.
The 2nd page you posted is for a LZW31 dimmer, not the LZW30 switch. Is that the back side of the first pic you posted? Inovelli has had some problems with their manufacturer and inserts, but please double-check in case you have more than one set of instructions and one is for the dimmer, as it looks like you have several pages of instructions.
Great catch! Pair that with the fact that I have just realized I was not pressing the correct switch (aux switch doesnt make a relay click) and this is solved. Oops!
Unfortunate that the insert was messed up ( yes that was the back of the on/off switch insert I received ), but my mistake takes the cake I think.
Just tested with the correct switch and it does in fact work perfectly.
